Coolest features you discovered after buying your Note 4
I just discovered s-photo that recognizes document through pictures for editing such as cropping and removing or other things. I hope it even has OCR which would be AWESOME!
So now I can also take pictures of documents and edit them if needed, priceless! It only captures the document too and ignores everything else. Damn sweet! Super excited here, can you tell?
Have you try to use the resized feature of some apps? Like calculator and calendar ... the app resized is going to be floating over your screen and you can move it wherever you want.
Long pressing of the back button is going to appear your multi window app menu at your right.
This is where I found the my places app and it is not accessible for some reason. Anyone know how I can get this to work?
It's a widget. A widget that only works with touch wiz launcher. Any other Launcher and you won't even see it in the widget drawer.
I get around the recent apps button lag by using the Side Key Panel (available in the Notifications Bar quick buttons area). It helps with one-handed operation, and there is no lag when you hit the Recent Apps icon. There is a similar function under Accessibility, Dexterity & Inreraction, Assistant Menu that provides more quick action icons.
I jus discovered, when u click and hold the button on s pen, then select the image at gallery, it will be tick every pic u select with . Its easy to delete a dozen of picture.
I like if you're on a task,etc and a call comes it displays at the top and you haven't lost page you were on.
I love that too, it always seems that when I'm in my calendar, a text comes in. Now I just reply real quick & go back to scheduling my appts....no more in & out of apps!
Posted From MY Next Big Thing!!
Related to that... being able to yell "Answer!" at my phone if my hands are dirty or something.
Started using the finger print scanner and really paid attention to how it works this time. After doing it properly, thr fingerprint scanner works pretty good.
Nothing but Note! A little rim, some backboard, but mostly Note!
Has worked 95% of the time for me which is good enough :-)
Yeah, it isn't bad.tw as initially disappointed because it wasn't as good as Touch I.D. For some reason, I decided to give it another shot and actually followed the visual directions of it. Now it works fine.
Glad like me your now enjoying the feature Doc :-)
I am. It makes me feel a little more comfortable when I set my phone down and walk and way with it. That someone just can't operate my phone.
The coolest feature of the Note 4 is simply having one. Loving my 2 day old Note coming from an iPhone 6 :)
Can't load pics, looks kind of crazy. Settings, device, accessibility, vision, then hit negative colors kinda cool
Was playing around in the settings and came across this.
paulmloucks
