Cream of the Crop
Can someone explain what different kernels do? Why are some better than others?
A link to something that will do the explaining will also work....
Thanks
Thanks
You can do a search and find some better explanations, but the gist is this: The kernel is like the engine of your car. In your phone, everything your ROM and apps do that deals with any piece of the hardware, commands have to sent through the kernel. The kernel is the link between the software and the hardware. A really well made kernel can increase your battery life, the speed and fluidity of your system, let you overclock your CPU for more speed, etc.
Thanks, as soon as I posted this question, the thread right above this one became a kernel expansion thread...so I read up. Thanks though, it makes sense.
How does this compare to AOKP? That's what I'm running now, but if this is better--I'll make the jump!
I was wondering the same thing. I'm probably going to try it regardless because I'm a flashaholic, but they do look similar. As of right now AOKP has more support for mods and things as far as I can tell
jmyoung48
