- Jun 5, 2011
- 47
- 6
- 0
I rooted my GS3 and installed CWM 6.0.2.3 using Rom Manager. I did about 3 or 4 nandroid backup without any issues. I renamed the backup files for easier identification. I noticed the dates on the backup files were wrong. The years were 1970 and the month and days were about 20 days behind. However, I have not tried the restore function of the CWM. I just flashed CM10.1 and did not like it and wanted to go back to the previous Android 4.1.2 by restoring from the backup. As I went into restore of CWM, it could not locate any backup files. I checked the internal SD card and I could see the backups were there in the backup folder of clockworkmod. I did another backup and without leaving CWM and went into restore. This time I could see the newly created backup file. I reboot the system and went back to check the new backup file and it was no where to be found.
I cannot be sure this is a CM10.1 problem or CMW 6.0.2.3 problem. Has anyone encountered this problem and what is the fix for it?
