[CWM][SOURCE] Pure ProjectVenom Recovery
Re: [SOURCE][CWM]ProjectPanda for Viper LTE
When i go to the website it has an installation guide.
Sent from my LG-LS840 using Tapatalk 2
I don't even understand the point of hacking my site? It's not really anything except a project's website , and as long as my database is online , CloudFlare caches the site and it can still be accessed , but they killed the database too.
There is no telling. They were probably bored and just wanted to mess with some one, or just learning. If it would save money I would use the free hosting
About 35% of the site is back up and running now, I just need to finish setting up the bug tracker and every other important module This may take awhile. Meanwhile, I have the graphics fixed I believe.
Sent from my SPH-D710 using Android Central Forums
Cool, I was wondering tho if part of our issue was our kernel. Doesn't cwm touch require an ics or later kernel?
CWM touch does, but he got the ics kernel source from LG's site a while ago.
Sent from my LG Viper 4g LTE using Tapatalk 2
Ok i didn't know he got it or was using it
Recovery fix will be posted in a couple of minutes.
I think I know where the reboot issue lies, in the postrecoveryboot.sh script. Only problem is, if I try to remove the offending line, you all will be in a recovery bootloop. ::banghead::
Does it have anything to do with the factory reset option if we use the second button combo? Volume up and power is recovery, while volume down and power is a factory reset screen.
Off topic is it bad I'm tethering my optimus s to get my ics fix.
Sent from my LG-LS670 using Tapatalk 2
I doubt it. ODIN Mode on my phone (E4GT) (Volume Down - Power) has no effect on the device.
And not really, I tether most of the time when I'm traveling to work , or on a ship so it's good I guess.
---------- Post Merged at 05:31 PM ---------- Previous Post was at 05:28 PM ----------
Recovery updated. Read CyanogenMod Rules in post #1, read the changelist in post #2, and download in post #4.
Oh yeah, I'm almost done editing a program I found on Google Code so we can flash from there.
PS, for you copyright people, the program was released under a license revision that allows editing, so I'm free to do it. :D
Ok graphics fixed but when i tried to do a back up it said unable to mount back up directory
Okay, rebooting there from the terminal. reboot recovery.
Also, Windows Recovery Flashing Tool now found in downloads. ;)
Also rebooting still hangs. Tried the commands you said and got this
Off topic again did you get my email?
Volume up + power doesn't boot to recovery for me
Ah, it can't mount /sdcard.
Reboot is still a no-go
And it appears that running an aroma installer crashes the phone
Sorry for not pushing a update today. I'm like REALLY sick , and I just got blood work done.
But as always, I will have news for you. I think I corrected the mount points , for the people that is having trouble mounting /sdcard. If you are having trouble, please use ProjectPanda Recovery 4.1 .
4.1 is set as private :confused:
Sorry, I did that so people wouldn't download the buggy versions and I don't know which is which. One moment
Hey, can anyone help me? My phone won't go into recovery I see the logo with an exclamation mark for 1/2 a second then it boots.
Wil it boot in to the phone os all the way? What method did you use to flash the recovery if you flashed the custom one? We really need more info other than it wont boot to recovery
Ashok Dharshan
