Cyanogen is playing tonight! :)
I dont think you can do this its not Sense...
Anyone know a Method of doing this?
on stock android 2.1 you can go to settings > accounts and add your facebook account but on CM6 it does not add. or I cant figure it out
You mean Stock Sense...
Stock Vanilla Android doesnt have that Feature as far as i know...
It was Def Facebook for Sense
Stock Vanilla Android 2.1 has this. the moto droid has this. if you go to settings accounts it allows you to add your facebook account. and then gives you the option to sync contacts. but for some reason i cant get it to work on CM. after i hit add account it open facebook like it should but the account neaver stays in the settings > accounts & sync settings. i was wondering if anyone has found a fix for this.
Originally Posted by jrgutier
Here's a quicker solution for Facebook. None of this push and pull crap. Cut and paste the following shell code to your CLI.
adb remount
adb shell sed -i 's/ro.product.name=htc_supersonic/ro.product.name=opal/g' /system/build.prop
adb shell sed -i 's/ro.product.device=supersonic/ro.product.device=sapphire/g' /system/build.prop
adb shell rm /system/app/Facebook.apk
adb reboot
Let it restart, then install Facebook from Market if you haven't already. Sync will work, a lot less effort.
From our friends over at XDA
Anybody else having issues with their notification bar disappearing?
Running the latest nightly, didn't wipe this time between builds.
PS, I strongly recommend and support wiping before you flash. I tried the 7/23 with out wiping, and it did not play nicely. Will fiddle more with it when i have time.
I've been doing that until the most recent build. I guess I got tired of having to re download everything (or have nothing) and so far I haven't had any issues.
Its working fine for me...
Before I flash the new builds i always make a back up
and if things get screwy i restore and flash again...
so far so good...
so far so good...
For some odd reason, it uninstalled a select few apps, and then wouldn't let me re-install them via backup... weird huh?
no worries though, i flashed back one night, NBD
jost10
