Cyanogen Issues... *ru.bootloader*
Update
Okay so I was finally able to flash another Rom... This time with Root...
SDCard works again...
I have an ENG-PC36IMG on here...
Im up to the part where i ADB the Recovery Img...
Wish me Luck
Another update
Okay im back...
This time with Amon RA
IDK what HBoot i have anymore i've been staring at skateboarding Androids all day...
Im attempting to move a copy of my nand backup from clockwork to the nandroid folder i just made lets hope it works
I've forgotten, what are you trying to do agian? Dont look at this as an hboot issue. You want Cyans rom right? So un root and then re root your phone in the old method. Then flash his rom.
Yea... My goal was Cyanogen
Turned into HBOOT
Turned into Getting root back
Turned into getting SD and USB back...
Got SD and USB + ROOT + Custom Recover
Now i need to check if i have HBOOT if not im at Square one with a subpar Custom recovery... Blehhh
K so where do i get the new nightly? haha
I've been so focused on this krap i dont know where to get the nightly builds
I'm having the same issue here. Still very much a noobie here, what exactly did you do to get this to work? Currently running baked snack v9.6 and using clockworkmod. No issues flashing any Rom but cyanogen's nightly builds. Thank god for back ups or I would really be screwed. Any advice or help as to how you finally resolved this issue would be greatly appreciated.
Wellllllllll
I went thru alot i basically started alllllll over again...
You need HBoot 0.76.2000
You need Amon RA to flash initially then you can use rom manager to flash clockwork back **which is what i did F Amon RA Bleh**
You need a wealth of knowledge in ADB and Fastboot no simple / Unrevoked methods here...
Best Advise Flash back to Stock and Re-Root via Toasts Method...
Goodluck and look thru here for the links i used for certain things...
I'm fully rooted now this time for real... and im loving it!!!
rvrsco
