- Dec 24, 2011
- 159
- 13
- 0
Oh yeah I completely forgot to mention - iif you have Windows, go here. Android SDK | Android Developers
I don't think you really grasp what you're talking about here. Say you get a cm7 distro compiled for the vm slider. You're going to have to be able to debug the distro... you're not going to get a perfect compile off the bat.
Since LGE does a horrible job with their source, you're going to need to be able to decompile their kernel's and .apk's, .jar's, etc. to pull lg specific code. The slider doesn't even have a 2.3.7 aosp yet (though aosp is harder than cm7)... Again I'm not trying to put anyone down, but if you dont understand the language used above you're not going to be able to port it. Also, if you dont realize you need to run linux or mac to build this.... (why that link was given above?) then you definitely wont be able to port this. I can tell you its more likely the Optimus Q will get it before the Slider (if either gets it). However, once the Q gets it, the slider will get it right after.
I'm in a really bad mood today so I'm sorry if I was rude above, its just this cant be compiled in windows, and that android sdk wont really help at all with it. Whoever takes on the task of compiling this for the Slider is going to have a slider, and will already know everything thats contained in that link...and will use the android sdk from a linux platform most likely.
okay i know i'm really dumb, but could i have some links to the sources and such? i have ubuntu running on my computer now so i can do it.Edit: Something that I'd like to see... Get the source from LG. Compile the source using their walkthrough, (basically you pull 2.3.4_r1 source from google servers (if the slider comes with gingerbread...idk it may come with froyo)) then merge the files they give you with the source from Google. Go through and correct the problems that are due to it being LG specific coding. (Really defeats the point of Open Source imo). If you get it to boot properly without hanging at the LG logo on startup and everything works. Merge your source with aosp 2.3.7 source. This would give you a gingerbread update. You'd also be running without CIQ id think. This would correct a few issues with the os itself, and should debloat your phone. Now... I do not know how VM works or if you update your minutes directly from the phone... if you do this brings in a whole new set of issues and the above may be very difficult to pull off.
I'm gonna try to port it to the Q. The only issue is that LG hasn't released the source code for the Q (they have for the Slider though.....)
Sent from my thumbs to your retinas
In case you were wondering, the source code for the LG55C has been released.
hows cm7 looking for the slider?...hopefully it fixes the battery bug...its really anoying, it doesnt last for crap.![]()
The optimus v? I had that one..I bricked it tho...now I won't charge or go into recovery or boot it stays on the black lg sing-_-Seriously.. makes me wanna switch back to the OV
Sent from my LG-VM701 Gelato 11-28 via Tapatalk
I remeber flashing rodimos rom and didn't boot up...then I tryed going into the recovery menu n it didn't want all it did was stay in the black lg logo -_-...yes battery life is better and the roms are faster...I recall asop rom was the fastes of all I tested...bobzhome is stable but a bit slow.How did you brick it? I may switch back since there are way more roms available and the battery life is pretty awesome compared to the Slider.
well shoot Ubuntu stopped showing up in my boot menu so um idk. is there anything that i can do on windows?
yes indeed no progress yet but we'll see later on plus I have to stick to this piece of lol...I messed up the wildfire s as well -_- hahahahI usually stick with MiRaGe, it has never failed me. Tried ICS on it, still nowhere near stable enough to use daily. Now the OV has different MIUI roms being ported to it thanks to Gannon, I have much more reasons to wanna switch back. Development for the Slider just isn't showing any progress whatsoever
Y
