CyanogenMod 10 Beta 2: Android 4.1.2 for the Epic 4G Touch
Re: [ROM] CM10 alpha5.3: Android 4.1.1 for Samsung Epic 4G Touch
I noticed the camera effects dont let the camera record anything on build 5.3 and my music files are repeated in apollo music player
I can confirm that. Its been a huge overlooked issue. And there is a real problem with the music. Its not only on Apollo that the files are repeated, it happens on most music players you diasporas from the play store..and the ones that aren't repeated, wont be recognized by the system at all as they used to be. And on top of that, there is a volume cap when music is played in any application.. So there is a serious problem with recognizing and playing music in the new jb music libs. Music is what i mainly use my phone for because i listen to music all day and i don't have an iPod so i can't use this as a daily driver as i would like to..and this was never fixed from the beginning
But that's my only gripe. Fantastic job on the development. I'm not trying to complain like a on here, i just needed to bring it to your attention. Keep up the great work
I noticed today.. there are a few apps that say " device not compatible" like words with friends among others.. is it because of the device name in the build.prop?
Sent from my SPH-D710 using Android Central Forums
Should add my SD card's file are all this way. pictures, movies, etc.
At least im not crazy lol. Glad im not alone on this adventure! Good luck! :)
I had to wipe both memory cards to fix the duplicate issue. I believe the duplicates happened from the mount points being changed. I didn't have that problem before JB. I just backed up the stuff I wanted to keep and wiped the rest (do at your own risk). After I did that it also calmed the media server down from 50%+ down to 4% as high as 20%. It has to be the way the file systems are mounted different from ICS and back.
No complaints or demands here, i'm well aware this an Alpha :)
Have noticed...
-The battery drain/super speedy recharge
-Quiet apps
-MMS issues, at least when recieving
-some occasional random reboots
and sometimes Google Now will crash if I make it think to hard :P
This build is still awesome! Thanks for all the hard work, and if I can help in any way let me know :)
I've been running this rom since early alpha. All was well until I flashed nightly version 20120911 and now I can't install any of my swype keyboards. I keep getting "settings has stopped working". Went back to last known working version which was Alpha 5.3. Still getting same error. Help please
Have noticed...
-Quiet apps
MMS shouldn't be an issue. Delete the telephony.db and reboot.
I had that with SwiftKey 3 on 5.3, and I just went into settings>language and keyboard and checked it from there.
Thanks, that did it. Something so simple that I was pulling my hair out.
How's 5.3 compared to 5.3?
Sent from my SCH-R760 using Android Central Forums
You mean how does 5.3 compare to 5.2? If so I've been running it since 5.1 and I've started the nightlies. 5.3 is very stable and smooth. Check the first post for Phantom's change logs and version info.
- - - Updated - - -
1. Thank you so much Phantom for bringing JB to our fones
2. I did look (maybe not hard enough but i tried nonetheless), when I use either Skype of Google+ for video chatting it wud force close n not work properly.
2A. Is there a possible fix or workaround for that issue because I would like to use rom as my DD
Try ooVoo, that's what I use.
Loving these nightlies!! Thanks Phantom! I left for a while and ventured out into the great android rom nebula and was drawn in by some paranoia. It was a good rom, but not as good as this one. When even the nightlies are stable, how could I not come back???
Quick question, after I Odin to EL26, I try to flash the CM10 zip but all I get is a grey triangle with a yellow exclamation in it. What does that mean I forgot to do, lol?
Edit: install CWM5, duh.. sorry this is only the second ROM I'll have flashed.
How is the latest nightly with volume?
Pretty good I only have problems with Google Voice when it comes to volume. That and I flashed Awesome Beats in place of DSPManager.
I used ti backup to freeze dspmanager when i installed the latest nightly and my music volume is almost perfect now. it gets the perfect amount of loud there just isnt anything past that(which isnt a bad thing im just not used to it) im not sure if it was a difference between this nightly and the prior one or if it was from actually freezing dspmanager.
anybody try this on fh13 or fio3? im on ff18 so far so good, battery seams to be taking a hit though
haymas
