CyanogenMod 10 Beta 2: Android 4.1.2 for the Epic 4G Touch
Re: [ROM] CM10 alpha4.3: Android 4.1.1 for Samsung Epic 4G Touch
Expandable notifications working? Dont know if I am doing it right. Help. Thanks
Re: [ROM] CM10 alpha5.3: Android 4.1.1 for Samsung Epic 4G Touch
What happened to all the updates on this.. seemed like everything just stopped
Sent from my SPH-D710 using Android Central Forums
The month of October was VERY busy for me at work. I had very little time to do anything. The nightlies broke around 10/2 due to some code being submitted to the galaxys2-common repo. chris41g has been working on everything in my absence. We just turned back on nightlies and have a pretty stable product now. Please carry on with your regularly scheduled flashing! :p
Outstanding update pPhreak!
sj
Sent from my pimped out E4GT on JB-AoKPm1 using Tap@Talk Pro 2.4
Not really sure
where do I find the nightlies at
Not really sure
The direct links to the file servers were posted 4 posts up from yours.
Sent from my SPH-D710 using Tapatalk 2
Not really sure, but where do I find the nightlies at
Where are you looking? Cause it still is being worked on daily
pPhreak: PhantomPhreak53 File Server
chris41g: Goo.im Downloads - Browsing CM or chris41g.devphone.org
sj
Thanks
So I updated to cm10 nightly 11/02 and now I cannot reinstall paranoid android 2.16 (last one I used since I read that the newest one has boot loop)
Wiped cache and dalvik
installed phantom's update
installed paranoid
Installed gapps for jb
and paranoid logo ran for 10 minutes and did nothing
So I reinstalled cm10 and gapps and now Google movies keeps crashing
Thanks
installed paranoid
What recovery did you use to flash? And have you tried to go to stock first, then restore/install next test? Remember, these are test builds.. its always best to restore to stock before testing, IMO
That version of PA might be a lower version compared to this build, so it might be necessary to restore to stock below PA v2.16
sj
Sent from my pimped out E4GT on JB-AoKPm1 using Tap@Talk Pro 2.4.1
Awesome rom, I love it. I just over from a LG Optimus S, my wife and I got s ii's for free. The thing I noticed that was mentioned once before with no answer is there appears to itmes the play store thinks aren't compatible that should be. My wife has rooted stock and I am running cm10. In the play store she has a lot more live wallpapers than I do. If I go to zedge and try to install a live wallpaper the play store says "your device isn't compatible with this cersion" Is this a known issue, or is this a slight oversight? Would a simple buildprop edit fix this?
From the looks of it, the latest build is very stable, great battery life, gyro/compass fixed, camera records all quality and video records at all quality's as well.. volume headset bug is on its way to being squashed, but still lingers slightly.. :/ but I'm very excited with the latest updates c41g, pPhreak and their team has posted.. :)
sj
Sent from my pimped out E4GT on CM10b2 - 11/09 Nightly using Tap@Talk Pro 2.4.3
I say everything But GPS is working on mine. But real stable so far other than that
Have you noticed a difference in the volume? That's been the deal breaker for me thus far in flashing this rom.
Hey, I don't post here often; but there's one major issue for me. I'm on the Nov. 15th nightly and everything seems to run fine, but sometimes my screen flickers and everything shuts down. I always have to do a battery pull and then put the phone back on the charger, and it's really annoying. Is this an issue with the ROM itself, or did I do something wrong? I followed all the instructions, so I believe I flashed properly.
I would nandroid and then restore to stock el26 then put your nandroid backup back on.. then if you're still seeing the issue, pull a logcat and post it here, the devs use that info to help track down replicate-able issues..
sj
Sent from my pimped out E4GT on CM10 - 11/16 Nightly using Tap@Talk Pro 2.4.4
Any way you can help me with the GPS issue? I've been looking for solid answer for three days...
Flash stock rom.
Lock GPS.
Pull battery.
Flash CM10 back.
Sent from my SCH-R760 using Android Central Forums
Can you link to a ROM. I've flashed 3 but no luck. Thanks
gaganprasad
