CyanogenMod 10 Beta 2: Android 4.1.2 for the Epic 4G Touch
Re: [ROM] CM10 alpha4.4: Android 4.1.1 for Samsung Epic 4G Touch
I had a problem with Apollo once. But not anything else
Re: [ROM] CM10 alpha5: Android 4.1.1 for Samsung Epic 4G Touch
New build up. UberPinguin figured if you compile the AOSP hardware_ril in place of CM, it fixed the Airplane Mode bug and LOS. This is just a temporary fix. UberPinguin is looking going to submit code to CM to get us back in to CM hardware_ril but this fix has been working and no known side effects yet. Please let me know if you experience any issues. I also updated the mount symlinks to be backwards compatible. May reverse depending on CM standards.
Downloads:
CM10 Alpha 5 ( Mirror )
- Temporary fix for Airplane Mode Bug/LOS - thanks UberPinguin
- Moved mount symlinks. Internal = /emmc and External = /sdcard
- CM Upstream
I'm on 4.4 and each time I upgrade to a new build, I do a full wipe. Is this necessary? Or can I just upgrade to alpha 5 over the 4.3?
I noticed airplane or LOS happened after I used 4g. Didn't have issue until I turned on 4g. Ever since I have airplane issue. I hardly ever use 4g. This was on v4. Will install 5 and test out.
Sent from my SPH-D710 using Android Central Forums
Just want to add Phantom your a genius. so is everyone who helped you. Thanks guys.
-note today on build 4 my clock disappeared in my notification bar. i was able to get it back after changing system, statusbar, am/pm to full, then back to default and it came back.
and by the way. i didnt have to change any apn settings the cm teams original file worked fine.
Great no loss of service. Looking good man
I might give it a shot tonight
Alpha 5 is working great for me right now. No LOS yet, BT streaming works, and it reboots without updating all my apps.
GPS is sluggish, it takes about 2 minutes to get a fix, and the media scanner keeps my CPU pinned at 1200 until I force close it. But it's definitely a daily driver.
Sent from my SPH-D710 using Tapatalk 2
New on build 5, when I hang up a phone call the home/menu/back/search buttons stop working. A quick lock and unlock fixes it. Anyone else having this issue?
that's a weird one .. I have been able to make calls with no problems .. also in Phantoms other thread no one has mentioned it yet. Did you do a clean install of ROM and linked Gapps? maybe try reinstalling?
Ok been having this.problem since alpha 4.3, i.cant seem to get any of the builds after that to install i.keep getting a error saying some symlinks were.not made ive tried going back to GB and using the el26, twr, cwm 5, rouge and regular recoveries and still the same problem I honestly dont know what else to try any.help would be appreciated thanks.
Getting a symlink error "some symlinks werent made "when trying to.install any build past 4.3 and after it just sends.the phone into.boot.loop when trying to flash anything else
Edit: im on stock GB el26 cwm (tried rouge but.it fails automatically)
make sure you install ithe correct kernel in the op. it fails for me flashing from el 26 too
Hi All,
New to this phone and just installed this ROM. Absolutely love it... and am enjoying the Google Now features. One question though.. there is no default Sprint Voice Mail App so my voice mails keep going to sms from 9016. I found the latest SVV apk and installed it. I get the voice mails just fine in the app, but I still get the 9016 texts. Is there anyway to stop the texts from 9016?
Sorry if that has been asked before, but I didn't see it in the previous posts.
thanks for.the tip but i tried the kernel in the op(latest 8/21 and an older one) still the symlinks.fail so I odined backed to el26 for now.
try this it may work for you
1. try the el29 restore method (just google it)
2. then odin flash the el26 kernel
3.go to the el26 recovery locate the 41g wtf kernel and flash it.
4 then try flash the alpha 5 along with gapps.
its a long process but full proof process for me. let me know if it works pm me if you have any more questions
Patty60205
