[CyanogenMod-7 ROM+KERNEL] OM-Mandylion.....01-12-2013..Update
Re: Alien CM7 v1.01
Yeah I am rooted and I do have a custom recovery, for some reason it's not working. I'll try again later.
Re: Alien CM7 v1.01
Can't install it, says
E:Missing file:
system/app/AndroidTerm.apk
Check the zip, maybe a bad download.
I downloaded the file 5 times, none of them have worked for me.
Are you Rooted and have a custom Recovery? Yes the AndroidTerm.apk is not there as it is not needed for custom Recoveries and rooted OV's that are all ready activated.
I have no problem.
Yes, the deleted files messed up the update script. I tried to install also, I would turn of Verification, but I have to use ADB, so it's impossible for me. I want to flash it, but the script is thrown off. I'll try to edit some files, see what happens. :P
Re: Alien CM7 v1.01
What recovery are you using, and are you wiping/formatting the system partition. This is not a Update ROM, this is a Edited Custom ROM and everything must be wiped before flashing.
If anyone else is having a problem with the AndroidTerm.apk missing let me know and I'll upload a version with that apk's.
Re: Alien CM7 v1.01
I edited the zip then flashed. You must be using ClockWorkMod, so it doesn't verify the rom. I'll post the Xperia S Launcher in a little bit. It's shiny. :P
I installed with no problems. Then again I'm using Xionia recovery. Turned signature verification off and flashed. Only prob I have is force reboot using titanium backup.
Re: Alien CM7 v1.01
Here's the latest launcher, That I know of, From Xperia S, I think. :P
It has it's own Transitions when you launcher app. And when you click the home button, you get this little shine on the dock.
Re: Alien CM7 v1.01
The RA Recovery that I use by default has the signature verification off, but from my understanding is it only works on the older OV's.
Re: Alien CM7 v1.01
I'm with Leslie Ann and having a personal dislike for Titanium Backup and that is why I included MyBackup Root in this ROM.
Re: Alien CM7 v1.01
I'll reflash and give MyBackup a try. Never used it i may like it. Thanks for info.
Re: Alien CM7 v1.01
I like it, Titanium Back is way to techie for what I need to do; I understand but it is way over the the top. MyBackup Root is a simpler UI and makes it more pleasing to the eye, at lease that is my take: plus it does restore Market Links for your apps.
Re: Alien CM7 v1.01
@earthfire nice screen shot, I see we have the same style,:) currently using same livewallpaper,se launcher,Walkman music,favorite people widget, and a couple more ;) on latest backside, if I didrent already had it like this I would had definitely FLASH!!!! thanks for posting this rom!!!!!!!
Re: Alien CM7 v1.01
Yeah upload a version with the apk's needed please :D
*Using Xionia recovery.
Yeah the AndroidTerm.apk was missing for me too. So I turned off the verification and it got stuck in boot.
Re: Alien CM7 v1.01
The ROM with the AndroidTerm.apk will be up shorly: check the first post for the update. There are going to be two versions; one with AndroidTerm.apk and one without, both should have the Updater Script fixed, and couple of more things add to make the ROM more stable, still need to do a complete wipe before flashing.
Did you tweak this rom? Or theme?
Just add a couple things that needed to be added.
Edit: the new ZIP file well be ready for download in 12 minutes, check first post for the update, and for the sack of not confusing anyone decided to just post the version with the AndroidTerm.apk.
Re: Alien CM7 v1.01
Does Gingerbread have flashable status bars like Froyo has?
Yes only, but they have to be compatible with the ROM they are being flashed to, other wise could cause boot problems. Right now I;m working on one for this ROM, but must likely will not be ready for some time.
Re: Alien CM7 v1.01
I can't win with this rom xD
Now it's telling me system/app/VisualizationWallpapers.apk is missing. Is anyone else getting this?
spade20
