[CyanogenMod-7 ROM+KERNEL] OM-Mandylion.....01-12-2013..Update
Flash both the ROM and Gapps. Make sure you wipe and format everything but the sd card.
DOH!
Sorry. Forgot this ROM and the Harmonia2 include the Gapps (Big no, no though with Google).
I just updated this ROM today. It was a little rocky, automatic install wouldn't work and had to do it manually. So far, looks like it's running great!
I backed up up all my apps data, then restored and it worked well. However, is there any way to backup all the shortcuts and widgets on the home screens? I'm having to create them all again.
Thanks!
Depends on the launcher.
I use Lancher Pro with the Pro key.
It allows me to backup all screens.
Aftef a batch restore witb Titanium Backup all my apps are right where their supposed to be.
Thanks AndyOpie150. Maybe I should try that launcher. So, with the launcher that is built into this rom there's no way to backup the screens?
Don't know. Go to it's menu and see. Been to long since I had it on my phone. Launchers might be different.
EARTHANDFIRE can u release a build with Koush's new open source superuaer app? And all my apps are having problems updating now saying package file invalid. Any ideas?
Sent from my VM670 using Xparent Pink Tapatalk 2
I'm having the same trouble updating my apps. There's always an error message Package file invalid.
What is this for? Superuser is already installed is this one opensource like koush's
Can we get a kernel update or something? Have we been abandoned?
Prince08900
