Cyanogen's Nightly Builds
Flashed just fine for me off of rom manager.
No major improvements on benchmarks, smooth and creamy though. Oh and native wifi tether symbol changed haha. Will post back if I notice anything else.
help me help please...........running rooted stock froyo rom
ok i have a few questions please some one help me
-how do i know what radio or wimax do i have
-if i flash the new radio/wimax do i have to re-flash them every time i flash a new rom?
-how do i flash wimax, radio, kernel, Cyanogen?
i have clockwork and rom manager
4G does not work with this rom so forget that, if you want to flash this rom, just download it, nand backup, wipe, and flash as it says on the first page. I don't even know what radios I have or care. It works and that's all that matters.
hey igotsanevo4g
thanks for the quick reply
do you have the latest build?
and did you installed any kernel? (and if so did you installed the rom first and then the kernel?)
one last question how would i wipe?
creating a backup about to download the latest build
Yes I have 8/28 (gotta update my sig haha)
I just have the regular cyanogen kernel That's cooked into the rom so no worries about kernels, nothing fancy.
Go into your custom recovery, and then scroll with volume rockers to anything that says wipe and use the power button to confirm for all off em.
Make sure you back up your data first or it will be bye bye.
If you wanna take the lazy way out like me download rom manager in market and it does it all for you more or less.
Good thing about these roms is as long as you don't switch roms, you can flash the new nightlies over the old without wipeing :)
Hey guys, I'm being lazy tonight and I don't wanna search for it.....where can I find the Snap Kernels and the *Feather* ya'll are talking about? I would like to try them out too. Thanks in advance!
Flashing 8/29 now, I'll let you know how it works :)
Update- 8/29 works. Don't ask me what the changes are...
hey igotsanevo4g
whats the number in rom manager and does it have the custom kernel or is it still the stock?
It's the 8/30 in Rom manager.
Don't notice many differences yet haven't had it long enough but its fast as hell.
It's the cyanogen kernel as always.
hey igotsanevo4g
is it up on the rom manager app and if so what is the number?
( i installed rc 6.0.0 but notice that there is a rc2 6.0.0 so i was confuse)
hey igotsanevo4g
look under cyanogen nightlys and go to 8/30, or download it from the link in the first post by the OP.
to DL it off rom manager you must buy the premium version too btw.
I'm using snap v8.1 kernel now but I used stock for like 3 hours. Snap gets me better battery for some reason and helps performance.
stock cm6 kernel is fast and good too tho so no worries.
helios74
