Cyanogen's Nightly Builds
My latest Quadrant is 1940 with the newest SNAP and Cyanogen!
I cannot break 1800 Quadrant? Tried everything.
Does amount of apps have any effect on testing scores?
Also did you notice there are two 9/01 nightlies? I'm gonna try the 2nd one now.
what makes my evo so different then others?
just wondering how some evo are able to under volt to 800-850 (kernel flash 8.2 XXX)? what can i do to make it work? i would love for my evo to run 8.2 800 (more battery life lol)
hey liquidjesus
what do you mean by " not every one is partitioning properly" ?
what will this do and how would i do it?
With the snap 8.2 I have my volts at 925. That gets me 1190MHz stable. And no I didnt partition correctly but I am getting good Quadrant scores anyways.
I don't even have any partitions. Doesn't interest me, I'm happy without it and if it ain't broke don't fix it :)
hey Eric1987
that was the lowest you can go ?
8.2 925?
just wondering because 8.2 850 runs good on mine but when i put it to charge and it reaches full it reboots.... and i have wiped many times i guess its time for me to try 850+
Ok. Finally got 1906 quadrant.
Formatted sd card then re-flashed 9/01 2nd nightly with CM6-SNAPv8.2 850mv.
Gonna flash 9/02 now.
I wish cyanogen would tell us exactly what's in these each night lol
Has anyone noticed it takes at least 5 rings from another phone for your EVO to ring? I'm on 9/02 nightly.
yeah that's happened to me a couple times. I'm on the AC rom at the moment, so I doubt it has to do with your rom. Maybe its our radio updates?
hello all......so here i am running this rom (cm6 6.0.0) and everything is running smooth.
i notice that when ever the phone goes to roaming the phone looses data transfer and when ever i tried to make a phone call it tells me i am on the Verizon network and i have an unauthorized devise.
i have tried the nightly releases but its the same problem....
has any one had this problem ?????????
also i have notice that not all my face book pictures from my contact list sync. do any one know how to fix this?
tomfrost
