Cyanogen's Nightly Builds
I don't remember my MFLOPS from CM6 but have a nandroid and I'll compare but I'm getting 32.863 running at 998Mhz, I thought I was a bit higher than that. (I haven't stopped any apps or background syncing either but I usually don't)..
the camera just gets FCs instantly, bummer.
update to my previous post after a fix permissions in rom manager and a reboot my fps is now averaging 53
Do you have an LED app?
Turn them on and off then retry the Camera...
Also the Mflops with Linpack are well weird now
Use OXbenchmark or whatever its called it will show a true Mflop of 46 average I hit 50 once... 0_0!!!
Flashed 9/27 but market is not downloading?
EDIT: nevermind, it just took a while for the initial download. Must have to do with gapps syncing?
Just flashed the lastest CM nightly, 10/1
Noticed the name is different?
Says CM_Supersonic-full-101, not sure what "full" means?
Wish I had 4G here...maybe its working?
I'm also running the 9/30 and I'm noticing I can't copy and paste from any screen anyone else having this problem?
used the demo, not really into it. Wouldn't mind paying a few bucks to cyanogen to add the feature into the stock cam.
QuriousOne
