Cyanogen's Nightly Builds
hey just notice something
has any one been able to check there voice mail?
(by holding the number 1) i get an error helio blabla bla
any one?
Your voicemail sometimes defaults to *86 when flashing cm6
To fix go to
* Home
* Settings
*Call Settings
*Voicemail Settings
*VoiceMail Number
* Change from whatever it is to your full mobile with areacode ( XXXXXXXXXX) no 1 or hyphens
* Then hit the thanks button
Do the new nightlies have better battery life than the stable release? If I want to flash to a new nightly build from the stable release do I need to wipe?
I think they do
And you can flash right over
no need to wipe - only wipe if you have problems
on a side note - the nightly since 9-7 has broke charging while on the Car dock - FYI
Does anyone know why the LED turns green at 90% charge? Is the battery meter calibrated wrong?
I've been experiencing the broken "car dock" charging too. I have a USB car charger and it's been screwing me lately!
I'm currently running cm6 and all of a sudden I can not get a GPS lock. I've tried everything I can think of. Any ideas. Is there a program that will check to see if my GPs working properly
Sent from my PC36100 using Tapatalk
Anybody else's notifications go quiet in the past couple nightly's? I don't get audible notifications other than calls.
Newest nightly fixes text notifications and let's u use yahoo on stock email app with wifi
ok, flashed 9/12 nightly and all seems ok.
Now let see what cm6-snapv7.6cfs_signed kernel can do?
EDIT: ok cm6-snapv7.6cfs_signed kernel is for real!!!
See sig.
Does it fix the charging issue. I charged my phone all night and didn't get above 76 percent
QuriousOne
