ARCHIVED: [DEAD ROM] LEGO-ROM-v2
Status
Not open for further replies.
Thanks guys! I reflashed LEGO and everything works perfect. You people make this stuff soooooo much easier!!!
Is there anyway to change the background on the lock screen? I use launcher pro and the wallpaper changes on that launcher fine, but it doesn't change the lock screen wallpaper. I am not able to change the wallpaper on the included launcher, on lock screen or the home screens. Is this functioning the way it was intended?
The way froyo works is, the wallpaper that is your home screen is also your lock screen, there's not 2 options (one for home and one for lock). Now regarding your other issue about is not changing at all on the lock screen. That's got do have something to do with either launcher pro or a setting in launcher pro because i just changed mine on the default launcher included with the ROM and ADW EX and in both cases it changed my home screen and my lock screen.
Wallpapers are controlled through the launcher. Since wallpapers and lock screen wallpaper are the same thing, and your isn't changing, you need to look at your launcher.
I use WidgetLocker from the Market. It's 1.99 but worth it. Lots of customization available.
Just wanted to say thanks to Beezy, Nick and Ksmith. This is great. Was easy to flash and gave me an extra 20MB or so of internal space. (of course, I'm sure cleaning out the apps helped with that, too ;-).)
Anyway, thanks again. I look forward to seeing updates!
Adding to ksmith post...some launchers have a 'lock desktop' feature. N that may cause unable to change wallpaper. Can check by menu - settings (or preference) depending on ur launcher.
i was wondering if you had an apk for the grid calendar widget that was in thunderom? i used it every day, and now i dont know how to get it back ):
Nice looking rom! Im flashing my gfs phone now.
Keep up the awsome job guys!! :)
Team work is all that counts to make things best.
G-Bread MikFroyo 4.4
There's a link called Widgets in post # 5 flash it and you should have the widget.:D
Reactions: justin926
Added 2 new themes and 1 old theme. Also added the alarm clock application to misc section from nROM.
Thank you guys!!!! I'm so excited, lol. I was getting ready for bed and I saw this...now I'm going to be up til 5am playing with my phone again. :)
What other Kernel's are there? I have just had my Optimus for a few days. I am having luck finding downloads for Zefie's and Stock.
We'll be adding more kernels soon. As you can tell this is like the working of making a bunch of ROMs at the same time so some stuff we can just pop out real quick, others it's going to take us slightly longer but the wait is well worth the reward.
Keep an eye on post #4 though, thats where the kernels will be and one of us will announce when a new one is put up like what we've been doing with themes and other stuff.
Quick question... anyone seeing double for all the sound choices (ringtones, notifications, etc)? I did the data/cache/dalvik wipe prior to install, then just Lego (reboot), kernel, TR interface, buildprop. Everything else seems to be running fine, but just noticed the duplicate entries in the lists.
Thanks for all the hard work :)
It's because you have a folder on your SD card called media that has all the ringtones and such on it from when you ran ThundeROM ;)
Status
vickyy
