ARCHIVED: [DEAD ROM] LEGO-ROM-v2
Status
Not open for further replies.
Yeah you can do that, then you might need to reboot. Try it see if that works. I figured that out the first time i flashed this ROM. We could make LEGO ROM delete that folder on flashing but the problem is we don't want to wipe out anyone's custom ringtones they may have in there.
You guys rock! Thanks for the choices. I'm really liking the TwoPointTwo theme. In the TwoPointTwo theme in the status bar would it be possible to change the "Ev" to "3G"? Its not a huge deal our anything it just reminds me of my old Samsung Intercept......looking back on it damn I hated that "phone" lol.
That took care of it, thanks.
On an unrelated note, I was wondering if anyone could possibly investigate the issue with Gallery3D taking up the proximity sensor sometimes and never letting up (even after killing the app). This is documented in several different threads on xda, and I've personally experienced it three times (all running TR builds, but I don't think that's related at all). I believe that once it was responsible for the incredibly flaky sensor performance I was experiencing as well when trying to make a call (as the Gallery app was shown to be using about 50% of the battery life, and ridiculous duration on the proximity sensor, just before I rebooted that time). The threads:
Gallery3d bug, sensor always on draining the battery - xda-developers
[Q] Do you suffer from Gallery Sensor battery drainage? - xda-developers
This thread is one of several I've come across that offer modified Gallery3d.apk packs, but I haven't been able to get any to install successfully. Attempting to delete the built in one using Titanium Backup and then downloading the version on the Android Market always fails at the app installation portion as well :(
http://forum.xda-developers.com/showthread.php?t=847656
Anyway, just was wondering, if you guys got the chance, if it would be possible to take a look and perhaps incorporate a working "fixed" version at some point in the future. Hopefully the version included with Gingerbread fixes this outright... but until then.
I've also experienced the gallery battery drain, probably 9 or 10 times. I had no idea of what was causing it though, this is very interesting.
This is one of the reasons I removed this theme!!! I didn't have a Samsung, but I hated the Ev icon. Also, in some of the custom themes, I've noticed that the unread count notifications in the notification bar are so large that you can't tell what is unread (i.e. Talk, Email, SMS, etc.).
Can you provide an example of 1 theme that your referring to? That will help in the troubleshooting process.
The Gingerbread theme with the round battery icon...I really like that theme, but it's unread counts in the notification bar are too large...almost oval instead of round.
Also, I believe it's the TPT theme...the GTalk notification cannot be seen in the notification bar or pulldown.
Unread counts? Do you mean like when you get enough notifications to generate the red "+" image with a corresponding number?
do you have to flash a build prop and kernal or can you just flash the rom and nothing elas?
You can just flash the ROM. Think of everything else after the ROM as mods or lego blocks that you can add to the phone after the ROM or base is installed.
Something I noticed today, I flashed Lego-Rom because I like the idea behind it. So then I picked a theme (mine), I then flashed Xionia kernel and proceeded to OC. My phone is stable 806 on thunderom and roms I have made. Lego at 806 would give me sudden reboot syndrome. Nandroid back to thunder and 806 is fine. Then I remembered I am still on stock lego build prop, flashed deluxe and no more reboots. Any reason why?
Thanks
Thanks
I think you explained why.lol Something in there doesn't like to run at that high of a speed without the stagefright enabled.
No, this is just like the Handcent icon on the notification bar...the "1" on the icon is just like a big red oval when normally it's a circle and you can still see the icon.
If I get a chance tonight, I'll put it back on my phone and test and take a screenshot and upload it.
so what are the difference between these
Some are compiled by zefie with his tweaks and adjustments,the others are compiled by me.I just made it so they boot at certain speeds for people that don't want to use setcpu.Flash them and run each of them for a day or two to see if there's a difference or if one runs better for you then the other.:D
Status
cenedo3697
