[DEAD THEMES] Optimus s Froyo -=Theme_Team=-
Re: [THEME] Reborn-Shell ROM Theme Kitchen --Theme_Team (NEW 7/2
the only link i see is to xda showing the boot animations for epic 4g it doesnt say optimus s
Very bottom of post #3 under the screenshots for the bootanimations and above my signature, there is a Downloads section. See attached screenshot.
Reactions: ikeywatson
Could you possibly do simpleG with no notification bar (100% transparent)?
Something like this:
[TIP]Be aware of which wallpapers you use with this one. Also, in certain apps, it will be hard or impossible to see some of the info in the statusbar. If you are using Launcher Pro or Go Launcher, this statusbar will not appear transparent. It does work with the stock Reborn Launcher or Zeam Launcher. FYI[/TIP]
Download:
theme_SG-tran-statusbar.zip
It didn't work for me using LauncherPro though. It showed the bar on my lockscreen and had a line underneath everything on my wall. Also, it showed a gap where the clock used to be.
If not I have a few things I think would be cool to integrate for notification icons if you can work with them. If not I understand.
This battery icon if you can:
[MOD][Theme Chooser] 4/12/11 Speedometer Battery Gauge with 1% increments - xda-developers
These signal icons:
ImageShack? - Online Photo and Video Hosting
This 3g logo if I can find it (or if you know where to look) :
http://i726.photobucket.com/albums/ww270/fourire/snap20110723_120235.png
and if that can't be found this would work.
3g notification bar icon image by Droid_Xer on Photobucket
And any other icons out there that are different and will go with it. This theme is going to be for a car setup on my phone, so something along those lines maybe? You guys are more creative than I am with this ha and if you find icons that may better suit a car setup that'd be cool.
And with a black notification background color, with whatever color you want for the icons.
This is just a suggestion so if you don't want to mess with it that's not a problem, just throwing an idea out there.
Thanks.
These signal icons:
Thanks.
As I stated when I posted the zip for ya, this will not work with Launcher Pro or Go Launcher. It does however work with the stock launcher and Zeam. Also the clock is still there, it is just black text so it does not show with the two mentioned launchers. Try either the stock launcher that came with reborn or download Zeam from the market.
I would be happy to further tweak this theme per your suggestions when I finish a couple other projects i have first. :)
Yeah I just tried it to see what it did but oh well. And alright cool, interested to so what you'll come up with. Thanks.
Hello, i am having a boot animation issue since installing this rom.. i hope someone can help me! i created my bootanimation. it has the desc file is correct. the pictures are correct and in the part0 folder. it is zipped in store mode. i placed the bootanimation in data\local. it is coming up blank screen. i also changed the permissions to rwx all the way through. it just will not work. =\ when i was on thunderom i made bootanimations and they worked fine.. but since this version. i cant get it working. someone please help!
PM me a link for it and I will take a look at it in the morning.
thanks alot! i appreciate. im PM'ing it now
hey, i tried to PM u with the attachment and i got a reply saying that moderators and admins cannot reply to technical questions =\
I just pm'd you. I think your image resolution might be too high or file sizes too big. I had the same problems before with high resolution images .
Yea jstntp thinks he is too good for us now. THATS why you get that message when you PM him. ;):p:cool: LOL just kiddin
thanks alot. the pix are 320x 480. If anything ill try to cut out some frames. or, i guess make the images smaller as u suggested. i appreciate ur help
How about a Honeycomb style theme?
Custom Launcher
Reborn's LG Launcher modded to have only three dock buttons (stock like)
Post #3 is updated with download link.
Awesome. How do you set the launcher to just the 2 items? Stuck with 4.
rob805213
