[DEAD THEMES] Optimus s Froyo -=Theme_Team=-
Awesome. How do you set the launcher to just the 2 items? Stuck with 4.
If you're using the 1 I posted yesterday in the reborn thread, redownload this 1 and flash it
I just re tested it and it worked fine.
See post 3
Re: [THEME] Reborn-Shell ROM Theme Kitchen --Theme_Team (NEW 7/1
Ok, here it is:
reTouched v1.1 -- Available with both "EV" and "3G" data icons.
Bluetooth status icons are "blue" = on and "green" = connected. I also changed the on/off notification icons too, I like the off images better now...... They are greyed out when toggled off
theme_reTouched-v1.1-noIQ.zip
theme_reTouched-3G-v1.1-noIQ.zip
Thanks so much for this! It's working out awesome for me!
Re: [THEME] Reborn-Shell ROM Theme Kitchen --Theme_Team (NEW 7/2
new Gmail update brought back the black Gmail icon. Reflashing a theme did not bring back colored notification ivon
my wife is in like with the purple durple theme. Is there any way to do that one with a black notification/status bar at the top?
Yep, solid black or stock Reborn black?
Is there a simple way to flash the stock Froyo launcher onto any of these theme options?
Yep....... I have included two diffrerent versions in this flashable zip.
One is the Stock Launcher and the other is my modded version of the Reborn Launcher to resemble Stock.
Use "Home Switcher" (FREE) from the market to switch to select your launcher after flashing.
stock_launcher_x2.zip (See two posts down)
So, we only have a "resembles" stock option and not the launcher from the Optimus V?
Ok, forget that link that I posted above. Here are two launchers to flash. Looking at stock screenshots it appears that the Stock Launchers are the same for the v and s.
Stock optimus s/v Launcher -- Launcher2_Optimus-s_stock.zip (Launcher)
Reborn Launcher modded to resemble stock -- LGLauncher-mod-ShellBorn.zip (LG Home)
Use "Home Switcher" (FREE) from the market to switch launchers after flashing.
Hope this helps :)
Reactions: Axe
Hope this helps :)
Maybe I was wrong...Does the Optimus V also have Sprint ID instead of the default world/browser icon?
Yes, but 99 % of custom roms remove the Sprint id. It's not located in the launcher. The launcher dock just houses the icon.
What Rom are you using?
Re: [THEMES] Optimus s Theme Kitchen -=Theme_Team=- (NEW 7/28)
Reborn ROM. Just curious about launcher options.
I use Zeam Launcher myself, but that modded reborn launcher I posted is pretty sweet if you like the stock three button look, because you can still change out the two launcher buttons to whichever app icon you wish.
Takyi Benedict
