Default [Help] Note 3 not automatically registering to network.
  • Start date Start date
A
AC Question
I live in a place where network is very weak and I lose it most of the time! My problem is that my note 3 doesn't automatically register to the mobile network thus every time I lose the the connection I have to go to settings>more networks>mobile networks> search and then manually connect to the my service provider. Is there anyway I could fix this? Please let it be known that my phone was bricked and the repair shop had to use a tool to restore my imei and SN. They are both now changed. I think the tool was called SPT. Please I think I need profession help! Thank you in advance.
4G-LTE Note3 international
You might have to call your provider and see if they can help you with network connectivity issues. It should be working automatically, and if you had sent it back for repair for the same reasons it's possible that they weren't able to fix it properly.
Sent from my Galaxy S4 running SlimKat 4.4.4
forget987
