Default Samsung S7 Edge Wallpaper
Liger86
10
Hi guys, strange question I know but I recently accidentally changed my homescreen wallpaper and now the default one has gone.
I have searched Google for hours and fail to find the turquoise(ish) wallpaper that came with the phone.
I have found one however it seems to have diagonal crisscross lines which the original didn't.
Does anyone still have the original or have a link to where I can get this, I don't even have a screen shot to show you what one I mean.
Thanks in advance as always!
If you go into wallpapers and themes on your device it should be under view all in the wallpaper section.
I checked there mate and its 100% not there which I find strange. It was just a simple background but it fitted in well with the apps and icons I have on the home screen. Could it have maybe come with my launcher, will check that now.
Unfortunately it's not magerb but thank you very much for replying and checking for me. Looks like I'll just need to find an alternative.
Sorry I could not help you:( Maybe someone else will come to the rescue. Good luck!
this is the one i've had on my S7 edge since taking it out of the box last year.
I have this one Osubass is was a turquoise colour and pretty plain.
Thanks for checking though.
Are any of these what you're looking for?
No lines at all in that one, these are all on the Zedge app. Just download it and Search S7Edge and they'll pop up.
Andacar
