Deleted my OS!! Help!
<ID:0/016> Can't open the serial(COM) port.
Is your phone booted into Download mode when you're running Odin?
Did the COM box change colors to indicate that the phone was connected?
Have you connected the phone successfully to your computer in the past?
You'll have to solve the connection issue before you can proceed to use Odin to flash the firmware.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
we got same problem how can get fix im trying to root mysamsung tab3 SM-T310 then i accedentally deleted my os how can fix it please
help
Hi i was trying to root my samsung galaxy s2 with kitkat version but i accidentally restarted my phone after that i have flash almost 8 times kitkat and ics using odin 3.07 but only screen display with my model came up with with below yellow color caution ...i even try to unroot my device i get fail error it try to set up connection but it get fail please help me<ID:0/016> SetupConnection..
<OSM> All threads completed. (succeed 0 / failed 1)
put your tread in your cumputer c users
Welcome to the forums!
Does the device still boot into Download mode? If so, you can reload the firmware using a tool called Odin (just Google it; look for v3.07; find a source on XDA). You can find the firmware here - mouse-over the region codes to find your country. Instructions on using Odin can be found here.
hey my friend..i delete os from my galaxy s3 i9300 ...i put my phone in download mode but cant connected with odin ...what happend???? PLEASE HELP
hi i have accidently deleted my lg g3 operating system when i was trying to unroot my device and now i cant get on to the device it just stays in the lg g3 loading screen. I can get to the app that alows it to be rooted when i hold the volume and power key buttons but i cant install anything on it. Please help ???
If it's off, you hold Volume Up and plug in the cable from the computer, do you go into download mode? If so, you can flash a new OS. See the XDA Forum for your carrier. There are links to the flashing tool and the tot or kdz files (you can flash an LG either way) for KitKat, at least. (I haven't looked to see if there are links to Lollipop files, but if you flash KitKat, the phone will update if it's not rooted.)
Sir i cant get to download mode and it wont turn on . when i try turning it on it just show the text galaxy tab 3 then it off . i cant also go to recovery mode or download. i really need your help :(
]I'm having the same problem - rooted, tried to unroot and managed to screw it up to the point that the tablet boots into recovery mode but not into download mode. All I wanted to do was clean this bloody thing up so I could return it...
Here's what I did:
1. Deleted SuperSU
2. Did a fectory reset
3. It booted into Recovery Mode, so I hit reset, then wipe cache (I think...)
4. put the SuperSU zip onto a microSD card, installed it, sent it back into recovery mode
5. Can't get into Download to fix the damn thing.
Ideas, or should I just try to return and hope they don't turn it on until I'm gone?
OK, nvm, got it into download mode. Now what rom is the one for the US?
if you can get it back into download mode, then look for the knox code and if it changes from 0 to 1 or says 0x10000 instead od 0x0000 or anything changes besides 0 (0x000) your phone has identified that the system was faulted by the flash and therefore your warranty is now void because the knox security system has changed from the original setting. If it says custom most likely it has detected as well that the system was flipped but because you said it still says samsung official they may let it slide. But im not sure what that means i believe is that the phone is an official samsung and that the flash was an official samsung code but it wasnt the original code on the phone. Sometimes a flash on the phone will change the imei so that could mean why the phone is now custom, More than likely though the repair person will have to flash your system anyway and if that doesnt work then your motherboard isnt being read by NAND and you probably need a replacement, i have been up solving mine and calling eveyr technincian store, repair person, and customer service since my phone did what yours did about 3am this morning. Ive got no sleep had about 3break downs and sadly i think it needs to just be professionally checked. My NAND keeps getting a write fail and nothing is passing over to my phone. i can still get into the recovery mode to perform factory resets and cache wipes but it says dm-veridity verification failed and even after multiple factory resets and cache wipes and accidentally hitting the adb button it has led me no where but a continous boot. My phone is only 12days old. Samsung will cover it because i didnt knock my warranty or show evident of any faulting with the OS. The phone had done a update to a new firmware and once that finished i did a factory reset from the phone settings and when i went back to wipe the cache the phone shut down and since then hasnt been able to go past the logo SAMSUNG GALAXY s6 screen powered by android. So as upset and dissastisfied as i am with the phone, i definately appreciate all the youtube videos, forums, repair technicians, and customer service advice i got today. I have definately learned more than i needed to know lol and downloaded about every type of odin available and both firmwares for the lollipop 5.1.1. for samsung galaxy and the original 5.02 the 5.02 got the farthest in download until it shut down because of the written fail and then again because of COM port, but the other one didnt even get past system configuration so i guess something needs to be looked at immediately. If you know anything please do respond back to this message before i send mine off thanks a bunch lovelies
my phone is a samgun galaxy s6 with model SM-G290P (sprint), i was originally on android 5.02 i guess but i got the phone activated in stores so when it was given to me from the moment i had it i was on 5.1.1. , i also noticed that my phone goes through odin mode easily but wont connect to the computer i have installed the smart switch, uninstalled after it failed to work with kies, i have installed the mobile drive individually and it picked it up on odin but wont pick it up on smart switch. I do know that if i can locate my s/n number then i can just plug it into smart switch to do the factory flash but i cant locate the s/n number being my phone is turned off. i tried the DEC,HEX AKA IMEI, ICC ID, RS UNDER THE BARCODE, AND none of these codes seem to be a valid s/n number. if someone could assist me with that i would be TREMENDOUSLY GREATFULLLLL!!! ALSO BEFORE i could just click my power button once and the phone would come on now i have to slightly hold it a few second for it to even show the logo.i have also noticed that if i charge my phone the phone loops otherwise if i go to download and cancel and then power on the device manually then it shows the logo once and then shuts off. so hurt you guys!
ALSO WHEN MY PHONE IS OFF I CAN SEE THE BATTERY IS CHARGING RIGHT NOW IT IS AT 82%, sorry for the caps i was typing and reading the phone. On the recovery mode update using ADB is disabled apparently and so is the option to update using external storage the apply update from cache is deprecated too and also when i started having a problem when i hit the power button home button and the volume up it showed the little android man died now it shows he is ok and up right like normal but the dm-verity verification failed still , I AM ABLE TO SEE EVERY LOG IVE RECREATED IN RECOVERY UP UNTILT EH VERY FIRST CACEH WIPE I DID THE DAY AFTER I RECIEVED THE PHONE. IS THERE A WAY I CAN TAKE THE IMAGE OR INFO FROM THIS TO REFLASH THE PHONE MAYBE?!!?!?
Hey there so I rooted my s3 then I wanted to unroot it, so I thought ibwould wipe everything and it would be okay, but then once I wiped everything my phone was stuck in boot mode, I can go into download mode but that's it, what do I do???!??? Really urgent please help
Hello, Im here to help you with your phone. so here is what u need to do. go and find the Samsung galaxy s3 android iso file on the internet, download it. then plug the phone into the computer that you r using and it should pick up on the connections. the access your devices files from ur pc and load the iso file onto it. This should fix your phone. Good Luck:) - JJGameCorp
I've rooted my Galaxy note n7000 and installed CWM..so then I was going to flash Cyanogenmod...but everytime I tried to install it failed and later when I wanted to reboot my phone it won't boot...just boots into CWM every time I power on.....and I realised that my OS is gone...now what do I have to do to get it back?? Should I flash a stock firmware or a rooted firmware or some ROM.zip file....please help..with a little details cause I'm new in rooting!!!
i also deleted my os and my tab 3 was running on 4.1.2,the only thing you see on my screen is samsung galaxy tab3,please help
same for me, my galaxy a300f ave no os, i accidentally deleted my OS using TWRP, i cannot got to download mode, and even recovery, i tried ADB and SDk but my phone isnt responding, its stuck in Samsung Logo.. it doesnt turn off either..pls help.,help.,helpp
deleted everything.....due to the TWRP
ok i call myself trying to root my samgung galaxy note 2 so i could upgrade it from the 4.1.1. to the 4.4.4 system and i ended up downloading the Team Win Recovery Project (TWRP) app in the mean time. so i get to the warp official page and i got frustrated because i couldnt get back to my main home screen. so i did a factory reset inside the app thinking that it will just delete the app i was in but it deleted everything including the root that was need to even run the app. and now im stuck in the TWRP app eveytime i shut my phone off and go back in....please help PPPPLLLLEEEAAASSSSEEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: deleted everything.....due to the TWRP
That wasn't an app you were in, it sounds like you were in TWRP custom recovery and it sounds like you didn't do a factory reset, it sounds like you wiped the OS and now when you try to boot it boots to recovery instead of system like it supposed to because it has no operating system to boot to.
Find your stock firmware for your specific model number and your region(country) at Sammobile or at samsung-updates.
Install Odin on PC.
Make sure drivers are installed.
Boot the device to download mode by holding the volume down+home+power button, when you see the caution screen press volume up to enter download mode.
Connect your device to PC.
Flash your stock firmware via Odin.
alexsonburgus
