[DEV] LeWaOS Port
okay so i have an idea. the cm7 will boot but i doesn't have service. but it says u need cm as a base to flash lewa. then why dont u just flash the cm7 rom. then flash lewa.
That won't work. The lewa rom will overwrite cm7. What "use cm7 as a base" means is you have to inject parts of a working cm7 ROM into lewa. What parts? I have no idea, but I seem to remember a guide floating around somewhere.
but that cm7 does have working parts. just not all of them.
You're missing the point. You can't flash lewa over cm7 and expect it to work, as it will overwrite cm7 completely. It's like a puzzle. You have to have the right pieces in the right order, or else you end up with a jumbled mess (or a miniature useless mess like Mike Teevee in Willy Wonka :p).
Yeah and honestly the cm7 needs to be recompiled. Ill have to do a lot more to it. I don't think rgh seemed to enthusiastic about it. I've fixed a lot of the kernel issues, but the libs need to be fixed too. Its a long process. I'm not positive we can get it going we'll see.
Sent from my LGL55C using Tapatalk
Lassi876
