[DEVS ONLY] ics repo
Code:
http://pastebin.com/KHF7cnsf
I have been looking into these errors, could anyone lean me in the right direction? Any help would be great.
I get this error.
Code:
No rule to make target `vendor/lge/thunderc/proprietary/LS670/bootimages/sprint_power_on_00.rle', needed by `out/target/product/thunderc/root/bootimages/sprint_power_on_00.rle'.  Stop.
New error
Code:
target thumb C: libpixelflinger_static <= system/core/libpixelflinger/codeflinger/disassem.c
target thumb C++: libpixelflinger_static <= system/core/libpixelflinger/buffer.cpp
target thumb C: libpng <= external/libpng/png.c
target thumb C: libpng <= external/libpng/pngerror.c
target thumb C: libpng <= external/libpng/pnggccrd.c
system/core/libpixelflinger/codeflinger/disassem.c:710: warning: initialization from incompatible pointer type
target thumb C: libpng <= external/libpng/pngget.c
target thumb C: libpng <= external/libpng/pngmem.c
target thumb C: libpng <= external/libpng/pngpread.c
target thumb C: libpng <= external/libpng/pngread.c
target thumb C: libpng <= external/libpng/pngrio.c
target thumb C: libpng <= external/libpng/pngrtran.c
target thumb C: libpng <= external/libpng/pngrutil.c
target thumb C: libpng <= external/libpng/pngset.c
target thumb C: libpng <= external/libpng/pngtrans.c
target thumb C: libpng <= external/libpng/pngvcrd.c
target thumb C: libpng <= external/libpng/pngwio.c
target thumb C: libpng <= external/libpng/pngwrite.c
target thumb C: libpng <= external/libpng/pngwtran.c
target thumb C: libpng <= external/libpng/pngwutil.c
target thumb C++: libstdc++ <= bionic/libstdc++/src/one_time_construction.cpp
target thumb C++: libstdc++ <= bionic/libstdc++/src/new.cpp
target thumb C++: libstdc++ <= bionic/libstdc++/src/pure_virtual.cpp
target thumb C++: libstdc++ <= bionic/libstdc++/src/typeinfo.cpp
Notice file: bootable/recovery/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/recovery.txt
Notice file: system/extras/ext4_utils/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libext4_utils.a.txt
Notice file: external/zlib/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libz.a.txt
Notice file: external/zlib/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libunz.a.txt
Notice file: system/core/libmincrypt/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libmincrypt.a.txt
Notice file: system/core/libpixelflinger/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libpixelflinger_static.a.txt
Notice file: external/libpng/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libpng.a.txt
Notice file: bionic/libstdc++/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libstdc++.a.txt
Target buildinfo: out/target/product/thunderc/system/build.prop
host Java: dumpkey (out/host/common/obj/JAVA_LIBRARIES/dumpkey_intermediates/classes)
/bin/bash: 2.3.4: command not found
make: *** [out/target/product/thunderc/system/build.prop] Error 127
make: *** Deleting file `out/target/product/thunderc/system/build.prop'
make: *** Waiting for unfinished jobs....
system/core/libmincrypt/tools/DumpPublicKey.java:27: warning: sun.misc.BASE64Encoder is Sun proprietary API and may be removed in a future release
import sun.misc.BASE64Encoder;
1 warning
New error
Code:
1 warning
Maybe try resyncing?
Alright guys, got a challenge for you. I've been stuck on this one for a little while. Just not letting me get past it.
Code:
target thumb C: init <= system/core/init/builtins.c
system/core/cpio/mkbootfs.c: In function ���_eject���:
system/core/cpio/mkbootfs.c:82: warning: comparison between signed and unsigned integer expressions
target thumb C: init <= system/core/init/init.c
target thumb C: init <= system/core/init/devices.c
system/core/init/init.c:42:35: error: sys/system_properties.h: No such file or directory
system/core/init/init.c: In function ���notify_service_state���:
system/core/init/init.c:78: error: ���PROP_NAME_MAX��� undeclared (first use in this function)
system/core/init/init.c:78: error: (Each undeclared identifier is reported only once
system/core/init/init.c:78: error: for each function it appears in.)
system/core/init/init.c: In function ���publish_socket���:
system/core/init/init.c:137: warning: implicit declaration of function ���strlcpy���
system/core/init/init.c: In function ���service_start���:
system/core/init/init.c:253: warning: implicit declaration of function ���setgroups���
system/core/init/devices.c:34:22: error: asm/page.h: No such file or directory
system/core/init/devices.c: In function ���fixup_sys_perms���:
system/core/init/devices.c:139: warning: ignoring return value of ���chown���, declared with attribute warn_unused_result
system/core/init/devices.c: In function ���make_device���:
system/core/init/devices.c:193: warning: ignoring return value of ���chown���, declared with attribute warn_unused_result
system/core/init/init.c: In function ���console_init_action���:
system/core/init/init.c:544: error: ���PROP_VALUE_MAX��� undeclared (first use in this function)
system/core/init/init.c:575: warning: ignoring return value of ���write���, declared with attribute warn_unused_result
system/core/init/init.c: In function ���set_init_properties_action���:
system/core/init/init.c:584: error: ���PROP_VALUE_MAX��� undeclared (first use in this function)
system/core/init/devices.c: In function ���get_character_device_symlinks���:
system/core/init/devices.c:361: warning: implicit declaration of function ���asprintf���
system/core/init/devices.c: In function ���load_firmware���:
system/core/init/devices.c:611: error: ���PAGE_SIZE��� undeclared (first use in this function)
system/core/init/devices.c:611: error: (Each undeclared identifier is reported only once
system/core/init/devices.c:611: error: for each function it appears in.)
system/core/init/devices.c:608: warning: ignoring return value of ���write���, declared with attribute warn_unused_result
system/core/init/devices.c:637: warning: ignoring return value of ���write���, declared with attribute warn_unused_result
system/core/init/devices.c:639: warning: ignoring return value of ���write���, declared with attribute warn_unused_result
system/core/init/devices.c: In function ���process_firmware_event���:
system/core/init/devices.c:700: warning: ignoring return value of ���write���, declared with attribute warn_unused_result
system/core/init/devices.c: In function ���do_coldboot���:
system/core/init/devices.c:794: error: ���O_DIRECTORY��� undeclared (first use in this function)
system/core/init/devices.c:783: warning: ignoring return value of ���write���, declared with attribute warn_unused_result
make: *** [out/target/product/thunderc/obj/EXECUTABLES/init_intermediates/init.o] Error 1
make: *** [out/target/product/thunderc/obj/EXECUTABLES/init_intermediates/devices.o] Error 1
system/core/init/builtins.c: In function ���__ifupdown���:
system/core/init/builtins.c:108: warning: implicit declaration of function ���strlcpy���
system/core/init/builtins.c: In function ���do_chdir���:
system/core/init/builtins.c:140: warning: ignoring return value of ���chdir���, declared with attribute warn_unused_result
system/core/init/builtins.c: In function ���do_chroot���:
system/core/init/builtins.c:146: warning: ignoring return value of ���chroot���, declared with attribute warn_unused_result
system/core/init/builtins.c: In function ���do_sysclktz���:
system/core/init/builtins.c:534: error: storage size of ���tz��� isn���t known
system/core/init/builtins.c:541: warning: implicit declaration of function ���settimeofday���
make: *** [out/target/product/thunderc/obj/EXECUTABLES/init_intermediates/builtins.o] Error 1
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
Note: Some input files use unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
gannon5197@icsbox:~/cna$
New error
Code:
I'm guessing your PRODUCT_PROPERTY_OVERRIDES has a syntax error.
This is what it looks like
Code:
PRODUCT_PROPERTY_OVERRIDES += \
    ro.com.google.clientidbase=$(CDMA_GOOGLE_BASE) \
    ro.cdma.home.operator.alpha=$(CDMA_CARRIER_ALPHA) \
    ro.cdma.home.operator.numeric=$(CDMA_CARRIER_NUMERIC) \
    gsm.sim.operator.alpha=$(CDMA_CARRIER_ALPHA) \
    gsm.sim.operator.numeric=$(CDMA_CARRIER_NUMERIC) \
    gsm.operator.alpha=$(CDMA_CARRIER_ALPHA) \
    gsm.operator.numeric=$(CDMA_CARRIER_NUMERIC)
Please do let me know if something has to be corrected.
I think there are some lines further down that that needs deleting. Like you might see duplicate Product property overides like:
and
ro.cdma.home.operator.alpha=Sprint \
and
thekraven, the lines I posted are the last from device.mk. it's basically cloned form your device folder.
post the whole file, and i'll have a look
Code:
# XXX
SUB_MODEL := LS670
# XXX: should be full_base_telephony?
$(call inherit-product, build/target/product/full.mk)
$(call inherit-product, build/target/product/languages_small.mk)
$(call inherit-product, vendor/aokp/configs/common.mk)
$(call inherit-product-if-exists, vendor/lge/thunderc/thunderc-vendor.mk)
PRODUCT_LOCALES := en_US es_ES
#PRODUCT_INSTALL_PACKAGE := vendor/google/gapps
DEVICE_PACKAGE_OVERLAYS += device/lge/thunderc/overlay
# XXX: this is non-standard
LOCAL_KERNEL_DIR := device/lge/thunderc/kernels/iscream2
LOCAL_KERNEL_MODULES := librasdioif.ko tun.ko wireless.ko
PRODUCT_COPY_FILES += \
    $(LOCAL_KERNEL_DIR)/zImage:kernel
    $(foreach f,$(LOCAL_KERNEL_MODULES),$(LOCAL_KERNEL_DIR)/$(f):system/lib/modules/$(f)) \
    device/lge/thunderc/bootimg/default.prop:root/default.prop \
# Publish that we support the live wallpaper feature.
    packages/wallpapers/LivePicker/android.software.live_wallpaper.xml:/system/etc/permissions/android.software.live_wallpaper.xml
# Keylayouts
#PRODUCT_COPY_FILES += \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/usr/keylayout/thunderc_keypad.kl:system/usr/keylayout/thunderc_keypad.kl \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/usr/keylayout/7k_handset.kl:system/usr/keylayout/7k_handset.kl \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/usr/keylayout/Generic.kl:system/usr/keylayout/Generic.kl \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/usr/keychars/thunderc_keypad.kcm.bin:system/usr/keychars/thunderc_keypad.kcm.bin \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/init.local.rc:system/etc/init.local.rc \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/init.thunderc.usb.rc:system/etc/init.thunderc.usb.rc \
# Drew's init stuff
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/init.d/08dalvik:system/etc/init.d/08dalvik \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/init.d/10apps2sd:system/etc/init.d/10apps2sd \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/init.d/87calibration:system/etc/init.d/87calibration \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/init.d/95zipalign:system/etc/init.d/95zipalign \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/init.d/96tweak:system/etc/init.d/96tweak \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/init.d/05mountext:system/etc/init.d/05mountext \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/spn-conf.xml:system/etc/spn-conf.xml \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/profile:system/etc/profile \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/terminfo/l/linux:system/etc/terminfo/l/linux \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/terminfo/u/unknown:system/etc/terminfo/u/unknown \
#WIFI
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/dhcpcd:system/bin/dhcpcd \
# BT startup
    $(LOCAL_PATH)/prebuilt/init.qcom.bt.sh:system/bin/init.qcom.bt.sh
 # Board-specific init
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/init.thunderc.rc:root/init.thunderc.rc \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/initlogo.rle:root/initlogo.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/ueventd.thunderc.rc:root/ueventd.thunderc.rc \
# OFFLINE CHARGING
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/sbin/bootlogo:root/sbin/bootlogo \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_00.rle:root/bootimages/sprint_power_on_00.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_01.rle:root/bootimages/sprint_power_on_01.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_02.rle:root/bootimages/sprint_power_on_02.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_03.rle:root/bootimages/sprint_power_on_03.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_04.rle:root/bootimages/sprint_power_on_04.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_05.rle:root/bootimages/sprint_power_on_05.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_06.rle:root/bootimages/sprint_power_on_06.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_07.rle:root/bootimages/sprint_power_on_07.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_08.rle:root/bootimages/sprint_power_on_08.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_01.rle:root/bootimages/sprint_power_on_09.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_01.rle:root/bootimages/sprint_power_on_10.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_01.rle:root/bootimages/sprint_power_on_11.rle \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_08.rle:root/bootimages/sprint_power_on_12.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_01.rle:root/bootimages/sprint_power_on_13.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_01.rle:root/bootimages/sprint_power_on_14.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/bootimages/sprint_power_on_01.rle:root/bootimages/sprint_power_on_15.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/sbin/chargerlogo:root/sbin/chargerlogo \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/black_bg.rle:root/chargerimages/black_bg.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_bg.rle:root/chargerimages/battery_bg.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_ani_01.rle:root/chargerimages/battery_ani_01.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_ani_02.rle:root/chargerimages/battery_ani_02.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_ani_03.rle:root/chargerimages/battery_ani_03.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_ani_04.rle:root/chargerimages/battery_ani_04.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_ani_05.rle:root/chargerimages/battery_ani_05.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_charging_01.rle:root/chargerimages/battery_charging_01.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_charging_02.rle:root/chargerimages/battery_charging_02.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_charging_03.rle:root/chargerimages/battery_charging_03.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_charging_04.rle:root/chargerimages/battery_charging_04.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_charging_05.rle:root/chargerimages/battery_charging_05.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_charging_06.rle:root/chargerimages/battery_charging_06.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_wait_ani_01.rle:root/chargerimages/battery_wait_ani_01.rle \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/chargerimages/battery_wait_ani_02.rle:root/chargerimages/battery_wait_ani_02.rle \
# Backlight
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/tsdown:system/bin/tsdown \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/MELFAS_FIRM.bin:system/etc/MELFAS_FIRM.bin
# Sensors
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/ami304d:system/bin/ami304d \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/hw/sensors.thunderc.so:system/lib/hw/sensors.thunderc.so \
# 2D (using proprietary because of poor perfomance of open source libs)
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/hw/gralloc.default.so:system/lib/hw/gralloc.default.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/hw/gralloc.thunderc.so:system/lib/hw/gralloc.thunderc.so \
# 3D
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/egl/libEGL_adreno200.so:system/lib/egl/libEGL_adreno200.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/egl/libGLESv1_CM_adreno200.so:system/lib/egl/libGLESv1_CM_adreno200.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/egl/libGLESv2_adreno200.so:system/lib/egl/libGLESv2_adreno200.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/egl/libq3dtools_adreno200.so:system/lib/egl/libq3dtools_adreno200.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/egl/libGLES_android.so:system/lib/egl/libGLES_android.so \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/egl/eglsubAndroid.so:system/lib/egl/eglsubAndroid.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libgsl.so:system/lib/libgsl.so \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libsc-a2xx.so:system/lib/libsc-a2xx.so \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOpenVG.so:system/lib/libOpenVG.so \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libC2D2.so:system/lib/libC2D2.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/yamato_pfp.fw:system/etc/firmware/yamato_pfp.fw \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/yamato_pm4.fw:system/etc/firmware/yamato_pm4.fw \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/leia_pm4_470.fw:system/etc/firmware/leia_pm4_470.fw \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/leia_pfp_470.fw:system/etc/firmware/leia_pfp_470.fw \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/a300_pm4.fw:system/etc/firmware/a300_pm4.fw \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/a300_pfp.fw:system/etc/firmware/a300_pfp.fw \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/a225_pm4.fw:system/etc/firmware/a225_pm4.fw \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/a225p5_pm4.fw:system/etc/firmware/a225p5_pm4.fw \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/a225_pfp.fw:system/etc/firmware/a225_pfp.fw \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/hw/gralloc.thunderc.so:system/lib/hw/gralloc.thunderc.so \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/hw/hwcomposer.thunderc.so:system/lib/hw/hwcomposer.thunderc.so \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/hw/copybit.thunderc.so:system/lib/hw/copybit.thunderc.so \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libmemalloc.so:system/lib/libmemalloc.so \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libmemalloc.so:obj/lib/libmemalloc.so
# Camera
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libmmipl.so:system/lib/libmmipl.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libmmjpeg.so:system/lib/libmmjpeg.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libmmjpeg.so:obj/lib/libmmjpeg.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/liboemcamera.so:system/lib/liboemcamera.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/liboemcamera.so:obj/lib/liboemcamera.so \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libcameraservice.so:obj/lib/libcameraservice.so \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libcameraservice.so:system/lib/libcameraservice.so \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/hw/camera.thunderc.so:obj/lib/hw/camera.thunderc.so \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/hw/camera.thunderc.so:system/lib/hw/camera.thunderc.so \
	#vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libmikecamera.so:obj/lib/libmikecamera.so \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libmikecamera.so:system/lib/libmikecamera.so \
	#vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libcamera_client.so:obj/lib/libcamera_client.so \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libcamera_client.so:system/lib/libcamera_client.so \
# Wifi
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/wifi/wpa_supplicant.conf:system/etc/wifi/wpa_supplicant.conf \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/wl/nvram.txt:system/etc/wl/nvram.txt \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/dhcpd/dhcpcd.conf:system/etc/dhcpcd/dhcpcd.conf \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/wl/rtecdc.bin:system/etc/wl/rtecdc.bin \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/wl/rtecdc-apsta.bin:system/etc/wl/rtecdc-apsta.bin \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/wl/rtecdc-mfgtest.bin:system/etc/wl/rtecdc-mfgtest.bin \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/wlan/cfg.dat:system/etc/firmware/wlan/cfg.dat \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/wlan/qcom_cfg.ini:system/etc/firmware/wlan/qcom_cfg.ini \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/wlan/qcom_fw.bin:system/etc/firmware/wlan/qcom_fw.bin \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/wl:system/bin/wl
# SD Card
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/vold.fstab:system/etc/vold.fstab
# Audio
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/AudioFilter.csv:system/etc/AudioFilter.csv \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libaudioeq.so:system/lib/libaudioeq.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/AutoVolumeControl.txt:system/etc/AutoVolumeControl.txt \
    #vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/hw/audio.a2dp.default.so:system/lib/hw/audio.a2dp.default.so \
# Device permissions
    frameworks/base/data/etc/handheld_core_hardware.xml:system/etc/permissions/handheld_core_hardware.xml \
    frameworks/base/data/etc/android.hardware.camera.autofocus.xml:system/etc/permissions/android.hardware.camera.autofocus.xml \
    frameworks/base/data/etc/android.hardware.telephony.cdma.xml:system/etc/permissions/android.hardware.telephony.cdma.xml \
    frameworks/base/data/etc/android.hardware.location.gps.xml:system/etc/permissions/android.hardware.location.gps.xml \
    frameworks/base/data/etc/android.hardware.wifi.xml:system/etc/permissions/android.hardware.wifi.xml \
    frameworks/base/data/etc/android.hardware.sensor.proximity.xml:system/etc/permissions/android.hardware.sensor.proximity.xml \
    frameworks/base/data/etc/android.hardware.sensor.accelerometer.xml:system/etc/permissions/android.hardware.sensor.accelerometer.xml \
    frameworks/base/data/etc/android.hardware.sensor.compass.xml:system/etc/permissions/android.hardware.sensor.compass.xml \
    frameworks/base/data/etc/android.hardware.touchscreen.multitouch.xml:system/etc/permissions/android.hardware.touchscreen.multitouch.xml \
# LGE services
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/port-bridge:system/bin/port-bridge \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/qmuxd:system/bin/qmuxd \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/init.qcom.post_boot.sh:system/etc/init.qcom.post_boot.sh \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/rmt_storage:system/bin/rmt_storage \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/netmgrd:system/bin/netmgrd \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/wiperiface:system/bin/wiperiface \
# Unknown (needed or not?)
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/cnd:system/bin/cnd \
	vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/e2fsck:system/bin/e2fsck
    ro.lge.vibrator_amp=125 \
    ro.sf.lcd_density=160 \
    persist.sys.use_16bpp_alpha
# RIL
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libidl.so:system/lib/libidl.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libril-qc-1.so:system/lib/libril-qc-1.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/liboncrpc.so:system/lib/liboncrpc.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libdsm.so:system/lib/libdsm.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libqueue.so:system/lib/libqueue.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libdiag.so:system/lib/libdiag.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libauth.so:system/lib/libauth.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libcm.so:system/lib/libcm.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libnv.so:system/lib/libnv.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libpbmlib.so:system/lib/libpbmlib.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libwms.so:system/lib/libwms.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libwmsts.so:system/lib/libwmsts.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libmmgsdilib.so:system/lib/libmmgsdilib.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libgsdi_exp.so:system/lib/libgsdi_exp.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libgstk_exp.so:system/lib/libgstk_exp.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libril-qcril-hook-oem.so:system/lib/libril-qcril-hook-oem.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/liboem_rapi.so:system/lib/liboem_rapi.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libsnd.so:system/lib/libsnd.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libqmi.so:system/lib/libqmi.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libdsutils.so:system/lib/libdsutils.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libdll.so:system/lib/libdll.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/liblgeat.so:system/lib/liblgeat.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/liblgdrm.so:system/lib/liblgdrm.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/liblgdrmwbxml.so:system/lib/liblgdrmwbxml.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/liblgerft.so:system/lib/liblgerft.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libbcmwl.so:system/lib/libbcmwl.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libdss.so:system/lib/libdss.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libril.so:system/lib/libril.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/rild:system/bin/rild \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/bin/pppd_runner:system/bin/pppd_runner
# OMX
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libmm-omxcore.so:system/lib/libmm-omxcore.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libomx_aacdec_sharedlibrary.so:system/lib/libomx_aacdec_sharedlibrary.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxAacDec.so:system/lib/libOmxAacDec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxAacEnc.so:system/lib/libOmxAacEnc.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxAdpcmDec.so:system/lib/libOmxAdpcmDec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libomx_amrdec_sharedlibrary.so:system/lib/libomx_amrdec_sharedlibrary.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxAmrDec.so:system/lib/libOmxAmrDec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libomx_amrenc_sharedlibrary.so:system/lib/libomx_amrenc_sharedlibrary.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxAmrEnc.so:system/lib/libOmxAmrEnc.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxAmrRtpDec.so:system/lib/libOmxAmrRtpDec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxAmrwbDec.so:system/lib/libOmxAmrwbDec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libomx_avcdec_sharedlibrary.so:system/lib/libomx_avcdec_sharedlibrary.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxEvrcDec.so:system/lib/libOmxEvrcDec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxEvrcEnc.so:system/lib/libOmxEvrcEnc.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxH264Dec.so:system/lib/libOmxH264Dec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libomx_m4vdec_sharedlibrary.so:system/lib/libomx_m4vdec_sharedlibrary.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libomx_mp3dec_sharedlibrary.so:system/lib/libomx_mp3dec_sharedlibrary.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxMp3Dec.so:system/lib/libOmxMp3Dec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxMpeg4Dec.so:system/lib/libOmxMpeg4Dec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libomx_nextreaming_divxdec_sharedlibrary.so:system/lib/libomx_nextreaming_divxdec_sharedlibrary.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libomx_nextreaming_wmadec_sharedlibrary.so:system/lib/libomx_nextreaming_wmadec_sharedlibrary.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libomx_nextreaming_wmvdec_sharedlibrary.so:system/lib/libomx_nextreaming_wmvdec_sharedlibrary.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxQcelp13Enc.so:system/lib/libOmxQcelp13Enc.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxQcelpDec.so:system/lib/libOmxQcelpDec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libomx_sharedlibrary.so:system/lib/libomx_sharedlibrary.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxVidEnc.so:system/lib/libOmxVidEnc.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxWmaDec.so:system/lib/libOmxWmaDec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxWmvDec.so:system/lib/libOmxWmvDec.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libqcomm_omx.so:system/lib/libqcomm_omx.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libstagefright_omx.so:system/lib/libstagefright_omx.so \
#    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libopencore_common.so:system/lib/libopencore_common.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libmm-adspsvc.so:system/lib/libmm-adspsvc.so \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/lib/libOmxCore.so:system/lib/libOmxCore.so \
# Bluetooth
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/firmware/BCM4325D1_004.002.004.0218.0248.hcd:system/etc/firmware/BCM4325D1_004.002.004.0218.0248.hcd
# FONTS
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/fonts/Noxchia.ttf:system/fonts/Noxchia.ttf
# IDC file
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/usr/idc/touch_mcs6000.idc:system/usr/idc/touch_mcs6000.idc\
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/usr/idc/synaptics-rmi-touchscreen.idc:system/usr/idc/synaptics-rmi-touchscreen.idc
PRODUCT_BUILD_PROP_OVERRIDES += PRODUCT_NAME=COLD.AS.ICE
PRODUCT_NAME := full_thunderc
PRODUCT_DEVICE := thunderc
PRODUCT_BRAND := LGE
PRODUCT_MODEL := LS670
PRODUCT_MANUFACTURER := LGE
CDMA_GOOGLE_BASE := android-sprint-us
CDMA_CARRIER_ALPHA := Sprint
CDMA_CARRIER_NUMERIC := 310120
thanks lot for helping me :) Haven't changed the product name to AOKP yet :P
Code:
# XXX
SUB_MODEL := LS670
$([B][U]call inherit-product, vendor/aokp/configs/common.mk[/U][/B])
   thanks lot for helping me :) Haven't changed the product name to AOKP yet :P[/QUOTE]
Look at the part that I bolded. Are you sure it's config[B]s[/B]? Mine is config
Well, while my phone is booting, I so have a little overhang, part of the screen is shifted to the left. Haha, quite funny looking, but the button locations seem to be in the same that they would be. meaning if the menu is to the left I still press where it should be and the menu will open. I have yet to look around for a solution as I just installed the rom.
EDIT:
I locked the screen and unlocked it and its fine? it shifted on the LG screen
New error
Code:
1 warning
Help Please :-[ Could it be because if the thunderc.mk file I created in the vendor/aokp/product directory?
If so, I can post that as well.
Lelix2603
