where in gods name do you find this?
Your answer:
Go to Battery History and tap on the bar that says "running".
It doesn't look like a button, but just tap where it says "Running" under the since last unplugged drop down menu.
Has anyone noticed any apps missing from the market? Such as Slingplayer and CBS Pro Football?
Well my upload speeds are certainly fixed with this update (averaging around 500) but my download is still awful at no more than 200. I was initially thinking I might have a phone with a faulty antenna but I guess not...
It's a random rollout over the air but most of us are manually updating using the file available on xda.
I have very mixed results after installing DI18. Sometimes the 3G speeds are decent, sometimes they are bad, including download speeds.
Not sure what is special about my case, except that in my home I am in an allegedly 4G indoor area (on Sprint's map) but I can't get 4G service. Maybe Sprint scrimps on provisioning its 3G towers here because they believe their own propaganda about 4G coverage.
At any rate, this inconsistent performance is not very satisfactory. I can't say my 3G network problems are solved. This weekend I will cruise other locations in town and test there. ...
this may be the same thing that happened with the last update- it took a while for google to reset whatever to allow protected apps to be downloaded off the market- they eventually will add this update to the list
