S Steelheader New member Jul 19, 2010 0 0 0 Aug 4, 2010 #1 Does anyone know of an application that will tell you the closest gas station that sells diesel fuel?
J jdbower Well-known member Jul 2, 2010 615 59 0 Aug 5, 2010 #2 I'm assuming you live in the US, in which case you can check out GasBot.
D dekcufi Well-known member Jun 11, 2010 417 6 0 Aug 5, 2010 #3 Steelheader said: Does anyone know of an application that will tell you the closest gas station that sells diesel fuel? Click to expand... i just use sprint nav it works great! who knew that going a block down and around the corner would save me 10 cents a gallon on diesel
S Steelheader New member Jul 19, 2010 0 0 0 Aug 6, 2010 #4 Thanks, GASBOT is what I was looking for. I've tried using Google Maps to find gas stations but it does not specify which ones sell diesel.
