Dinc2 Getting Neglected?
no one should be investing in 4g until 2 things happen... battery life gets better... and voice and data both trvel over LTE rathr then the hybrid CDMA/LTE. Once those 2 problems are fixed, then I'll switch. Till then, theres nothing wrong with 3g if you ask me
Battery life seems to be getting better with each LTE device so hopefully by next year LTE devices will have processors & batteries which will equal their EVDO counterparts. As for VoLTE, that's going to be much longer down the road. If VoLTE is going to be a requirement you might as well upgrade to a 3G device to hold you over for the next 2 years. I also agree that having (or not having) LTE would not be the most important factor when it comes to upgrading. ;)
THE INCREDIBLE 2 IS NOT GETTING NEGLECTED!!! Theres just a load of code to go through to actually break in this bad boy. ROM Wizards shall root this because they are freaking magic!!! I have faith in all you ROM Wizards out there!!! Our phones battery lives are in your magical hands.
downeychris
