disable white circle displaying when finger touches screen?
Hello! None of these worked with the new android (2018). Well at least with my phone J3 pro.
But i found the way.
Click SETTINGS.
Choose ADVANCED FEATURES.
Enable ONE-HANDED MODE.
You can disable it,all you need to do is go on About device and click on Build number for like 5-7 times and then Developer options will show and go down and click on the category Input on the bottom of the category you'll see Show touches unmark it and it will go away you welcome
Dude, you don't even need to do all that. There's an icon called NAVIGATION DOCK to run on and off. Just drag the pull down icon menu from the top screen and turn off that is all..
go to settings
Click smart and convienient options in oppo phone
Deactivate smart ball option
Go to swching off Assistive all option
Tgat grey white n black ball icon disappears.
Hope u find it in ur phones in different setting options.
Try using google saying assistive ball word.
i went to settings--- find the build number--- saw nothing--- found a number version--- tap it 5-7 times--- i become the developer--- LOL:D
for LENOVO S5 / Lenovo K520
got to SETTINGS --> SYSTEM --> Developer Options --> Scroll down V
V
V
look for INPUT --> SHOW TOPS (on/off)
Hi all,
Thabaxy here.. new to the android world..on Samsung Note 8.
I had this same issue of getting rid of the circle which appears upon tapping/touching the screen.
I tried some of the responses here but nothing worked until i went to
1. Accessibility
2. Interaction and dexterity
3. then Tap duration, turn off tap duration and feature deactivated
TheGreatApe00
