Disabling Battery Saver - Redmi Note 11
  • Start date Start date
A
Android Central Question
Hi,
I'd like to permanently disable the "Ultra Battery Saver" on the Redmi Note 11.
Obviously it can be turned off via the interface - but equally it can be turned on via the same route.
Why?
Because my son has parental controls on his phone, but print it into ultra battery saving mode just kills the apps which then don't restart as it comes out of the saver mode
Also... Telling batter saver to not optimise the apps doesn't help either.
I was wondering whether I could somehow remove the battery saver functionality from the phone altogether or disabled somehow.
Thank you
John
You can do it from your computer by using Android debug bridge. You have to enable developer options and enable USB debugging on your phone. Then download sdk platform tools here: https://developer.android.com/studio/releases/platform-tools . You might have to i
Download the Google USB driver from here and install on your computer: https://developer.android.com/studio/run/win-usb .
All of the steps are here: https://www.xda-developers.com/uninstall-carrier-oem-bloatware-without-root-access/
You can skip the pm list packages command by just getting the package name for ultra batter saver app at the bottom of the app info page for that app in your phone settings.
noroldie
