Discussion of the Fascinate root How-To
yes, have gone through all the steps completely. i'm pretty sure it's on the computer end, because the sequence first see's the phone upon starting the process.
what steps are you following? can you post the link... maybe I can take a closer look at what you are doing
Reactions: geckotm
i've rooted my own Samsung Fascinate, via instructions posted in the forums, and am trying to do the same for my girlfriends, but my computer keeps dropping sight of the phone upon the first reboot. Initially it will see it, and after the reboot, i've gone through the motions of disabling the media sync, waiting for the computer to see it, and sometimes it does, but it either won't or it comes back as USB storage. either way, the root is unable to finish because the computer doesn't see it as the phone anymore. i have reinstalled the samsung drivers as well. Help!, i'm sure it's something simple.
sounds like what happened to me when i first tried the one click root. your easiest route is to use one of droidxcon's odin packages.
Reactions: geckotm
Are you following the onscreen prompts in the one click? and using the current one click from droidXcon's sticky? We need more info here.
Samsung Fascinate Rooting, EB01, Return to Stock, Remove System Apps, Other How-To
posted by droid xcon 3-10-11...can't find the exact one i started with yesterday, but scroll down to preparation and go from there. i've even re-downloaded the fascinate_v02 zip file, extracted and placed it directly under c:\.
yes, i am. it all seems normal. finds the phone ok. i get the 'error, device not found' when it reboots and i've given enough time for the computer to re-establish the connection. thing is, the tray icon doesn't come back after the phone reboots the first time
is 'odin' the process of manually rooting via the command window and inputting the commands to root by hand?
Something that helped me was uninstall the drivers, connect the phone in download mode and it loads some sort of more basic drivers. I don't understand it but it corrected my huge problems.
To get download mode take the battery out of your phone, hold the volume down key while you plug it in. Hold it down till you get a yellow triangle graphic on the screen, and let it load it's stuff. Once the computer finishes loading drivers go ahead and reload the samsung drivers, and try again.
Keep us posted.
some insight and maybe i can get some other opinions as well. It seems there is a file native to the phone 'tool_bootlauncher.exe' which wants to run whenever the device is connected to the computer. I believe it is tied to the media sync. Whenever the phone is reconnected after the driver install, it goes through a series of 'hardware found' flags...android usb, android device, a couple others i cant recall, and lastely, usb mass storage. for rooting, this is all fine (at least the fascinate_v02 one click), but when the device is connected the second time to the computer, the verizon file takes over and regardless of disabling the media sync, will either connect as as storage device, or more commonly, not at all. Thanks sheepdog, the usb driver trick worked....for a moment. I did reinstalll the drivers and went through it again, and left the 'install software' from verizon to help interact with the phone pop up up to see if i could get further. i actually got excited, because though it didn't show my phone, it also didn't error out and actually got to exploiting my phone, then when it tried to replace files, i got the 'error, device not found'. So damn close. it's gotta be the dang startup files native to the phone and what it's supposed to do when it gets connected, but i'm at a loss. i will try it again in the morning, and if nogo, i guess post #5, though it looks scary. I'm no pro, nor even a novice, just know enough to get myself into trouble. Thanks to all who responded so quickly! i am amazed and in awe! i am grateful. Pointers and direction are welcome, cause i'm still scratching my head! Happy Hunting (thanks again sheepdog)
The odin stuff seems really crazy and intimidating, but it's SUPER easy, just follow the instructions and you'll be fine. My computer had a driver issue that blue screened my computer after about 7 seconds plugged in EVERY time. Use drop box to move files around if you need to.
Odin is the easiest, and most reliable flashing method. If the phone shows up you can't go wrong.
Reactions: geckotm
ok, maybe i'm a DA or was just too tired. i ran the one-click process again, only this time after reboot, i let the media scanning occur, never got the media sync icon, unplugged the phone, plugged it back in, got the usb icon(which wasn't always coming up in previous attempts), pulled it down and selected it to copy files from computer and then selected the 'mount' option for the sd card. waited a few, then hit 'enter' to continue in my dos window and waalaa! happy rooter! thanks!
Still trying to figure out why this isn't working. I've tried re downloading the drivers at least 5 times. I've tried going through all the steps multiple times but the same problem is occurring every single time.
"Testing if your device is connected. 'adb' is not recognized as an internal or external command, operable program or batch file."
My guess is its something to do with the new update over the air? Or maybe something to do with the drivers but if I've downloaded them over and over again successfully it shouldn't be a problem. Is there another one click program that I could use?
Sorry, I was out last night otherwise I would have chimed in on this because I had the same exact problem when I went through the 1 click root method. This was a known problem of not being able to mount the pc to the sd card. If you have downloaded and installed (by double clicking on the downloaded samsung driver file) the samsung drivers, usb debugging is checked and are still not connecting to the pc, you have to reboot the phone while it is connected to the pc via the usb cable that came with the phone, and usb debugging is still checked.
Reactions: DreMan1990
Alright, so I followed your directions. I turned off the phone while it was connected to the pc using the usb cable that came with the phone and made sure debugging was still on. It shut off, so I then turned the phone back on. When it is rebooting, as it gets to the SAMSUNG title I hear the connection to my computer being made. Also it gives me the option to open the files on the pc. So far so good. Now when it passes the Verizon Wireless title and it proceeds to run my background and starts scanning the media, it immediately closes the option to view files and I hear the disconnection being made on the computer. The debugging mode is still on and I did not touch anything during this process. Maybe there is something on my phone preventing it from connecting. Could it have anything to do with LauncherPro as my default? Or maybe just a simple setting such as mass storage/media player. (It is set to mass storage) Thank you for your patience.
While the phone is booting up, don't touch anything or try to open any files. Wait until your phone has completely booted up and the media scanning is completed. Then pull down the notification bar, click on usb connected, then click the gray "connect usb storage" bar, click ok. After it connects an auto play pop up should appear on your pc, click "open folder to view files", this is how you can transfer files between your pc and the phone.
So I have to have the sd card mounted when I do this? Wish it would have said that in the guide. Anyways I open to view files and I try running START_ROOT.bat but the same problem is happening. "Testing if your device is connected. 'adb' is not recognized as an internal or external command, operable program or batch file." When I hit the space bar the same thing happens.
StevieD49
