DISH+Thunderbolt+Sling Adapter=WooHoo!
From the Sling adapter literature that was in the box:
HD viewing you need 3Mbps or higher.
SD viewing 600 Kbps or higher
Mobile viewing 150 Kbs or higher.
From the Dish setup unfo:
Here is What You Need to Get Started
Sling Adapter only works with ViP? 722 or ViP? 722k HD DuoDVR receivers.
High-Speed Internet Connection (Cable/DSL/Fiber)At least 1.5 Mbps download bandwidth (WAN or LAN)
For DISH Remote Access Mobile App: At least 500 Kbps upload bandwidth
For DISH Online Computer Browser: At least 600 Kbps upload bandwidth
Additional recommendation for optimal viewing:
LAN bandwidth of at least 3.0 Mbps
Note: The faster your Broadband Internet connection, the higher quality your video will be.
This is for the adapter. I don't have the info for the 922 or any other Slingbox.
I have had a Slingbox Solo for a couple years now. Used it back in the day on my Blackberry Sh!tstorm 1 and it actually worked well on that (about the only thing that worked).
I have Fios 35/35 and it runs flawless on my TB. And I can access all my DVR content as well.
I just looked at the paperwork for my 922, and it says 150-600kbps as a minimum. But, even using WiFi connecting directly to the 922 from my Galaxy Tab, the picture quality is okay, but there is a several second control lag that makes it unusable. And that's just off the DVR.
Charlotte Breece
