Distorted color and picture when using boomerang app... help
  • Start date Start date
A
AC Question
I installed app yesterday. Took 5 quick vids no issues. When back on this morning to let me daughter check it out and I get green yellow and blue vids and some are distorted. How do I correct.
Love the app esp with my kids
I have a colour distortion problem with the boomerang app too,in my OnePlus 6
And the display setting is checked to default
And moreover I have tried checking the full screen option also
It didn't work anyway :/
Please reply if someone has a solution
I have Galaxy S8 and experience the same problem from playstore.
Use boomerang from IG and it works fine ....it's saves down too and doesn't need to post to your story. Thanks to the prior users for the suggestion!!!
My does not allow me to uncheck. It seems its already checked and locked so i cant even click on it
Okay so I finally fixed this problem on my S9 -
1. Uninstall boomerang app
2. Google- Boomerang version 1.4.3
3. Download version 1.4.3
4. Go to display and uncheck full screen mode.
5. Use Boomerang to your hearts content.
- I saw on a forum to disable automatic updates in the play store but i can't figure out how to do that.
** THANKYOU!! I tried everything and this is the only thing that worked
For the others. I'm using op6. And had the same problem. My
boomerang app display was on default but I've changed it into full screen, and the discoloration gone 😊
After searching for this issue I found another way to do it. Just do Boomerang within the actual Instagram app. Open Instagram, click the "You" picture at the top left, then change the camera to Boomerang. This worked for me. The app Boomerang that I downloaded from the Play Store has the same issue everyone else is having.
Samsung Note 8 user.
I tried this with my Samsung A8 and was able to post to Insta. You have to take the video and save it, then post the video from your gallery.
TheGreatApe00
