I've a new low entry model phone with Android kitKat (Celkon A35K - India) and it has all low end specs for internal storage (allows certain apps to be on SD card) and battery life is not good!
So the challenge is to adjust the usage of apps to maximize the battery life
Just switched to Google Now launcher and it is great.. but I suspect it drains battery trying to pull info for cards (My loca
I use 3 widgets -- Calendar, Analog clock, Google Keeption reporting is On)
On a general note, do any or some widgets drain battery (a la Gadgets in Windows) or it is specific to how they're built?
Thanks!
RK
Thanks!
RK
