Do NOT want ICS OTA Update Frusterated please HELP!
A Dirty Flash is what Verizon did when they released the OTA. Dirty Flash is when you install a new OS over another one so that you keep all your data intact. What is causes is a set of unknown unpredictable things to happen. Things that shouldn't be happening. Most of the time a factory reset will fix this and is usually the 1st things that VZW asks when you call into technical support for these issues.
Well this is rather interesting. I know they made or are making adjustments to the original OTA release on ICS. As with any new OS version there will always be bugs and such. App developers will catch up as they have been, however i've read reports that some apps are having issues with ICS still. ICS has been on other phones for quite sometime now it doesn't just pertain to HTC Rezound.
Regarding Gingerbread, I have it all configured to how I like. I can not flash roms or understand how to for the life of me so I stay relativley stock. The other thing is I'm now using a Mac so do a proper Nandroid and recovery over computer I'm finding nearly impossible and hard to understand. I've watched YouTube tutorials and read fourms, still no luck. Rezound pulls up ext sd card but can not be mounted or read due to the different drive format. Also ADB is a bit tricky i've tried to use terminate mac's version of CMD on PC and can't type prompts correctly to load usb device. I use tiB and have all my system data and apps saved so if ever have to do factory resets that's how I get all my stuff back and I also have root keeper installed.
tsmtool
