Does anyone have a solution for network connectivity at home?
techman#WN
I have network connectivity outside of my home, however, whenever attempting to access via WEP, my network rarely connects. Does anyone have any solutions?:):)
I don't know if this has anything to do with it but consider switching to WPA2 security. WEP is not secure at all and you're just as well off turning encryption off. Also, consider a firmware update on the router if needed.
Sent from my DROID RAZR using Tapatalk
im having the same problem. Away from home using static IP I connect no problem, but at home using non static IP I show connecting but can't do any internet. I know 100% my settings are correct.
What kind of routers are you both using? I connect to a E3000 Linksys with WPA2 and am getting N speeds(2.4ghz).
Do any of you have MAC address filtering turned on at your routers?
amaka
