Does anyone think its TOO big?
Is this device too big for you?
  • Total voters
Sorry if this has been mentioned but can the on screen keys be customized to be made smaller to utilize more of the screen? I want to use as much of the 4.65 inch screen as possible.Thanks in advance
I think with such high res you'll have plenty of estate left. I've used 5 different honeycomb tablets and none can change the size, but it's fine. I don't know if Google or the community will create some customization for it.
You would be able to use apps lower the screen dpi to make it and everything else smaller, but its not the best solution.
Bitterbuthappy
