Does flashing a custom CM10 rom remove kies air, all share, Wifi Direct, etc??
I think it is pretty common to have the lte toggle. Most of the aosp and aokp let you define what toggles you want to show
Sent from my X-Band Modem... TY Genesis
Thanks piizzadude. ;) I was wondering if that was the case. Do you know if any of the popular tw roms do as well?
I am sure they do.I am not familiar with the AT&T rom's so I could not point you to one specifically. Just hit xda and take a look
Thanks again, Skunkape60. I'll go have a look-see. ;) Personally, I should probably root sooner rather than later?as the longer I stay stock?the more content I am to just stay stock.
Btw, how common are LTE toggles in custom roms? After reading of many suspected LTE related battery drain problems . . that's may be one of my main reasons for rooting, methinks.
Like I said, Im not familiar with AT&T ROM's but the Sprint version doesn't have LTE toggles on stock or on any of the custom Roms I've seen.
Most AT&T roms have the LTE toggle, but the AT&T APNs prevent it. It mostly works for just Canadian carriers.
Actually there's way around some of that. I swap roms alot but I recently got a hold of a smart TV.
I figured you needed Allshare from Samsung. Google Play Store would not let me download Allshare because they said "it wasn't compatible." Really? With a Galaxy S3 from At&T?
I would just get the APK for some of it.
Google search to "Aptoide" May have to sign up.
You will have to install "aptoide" to get to the Allshare app.
I have the S3 i747 running CM 10.2 ROM.
Allshare now installed and runs fine.
May work for the rest of the apps you were concerned about. Worth a shot.
ChrisAndroid
