No. The DAC, or Digital to ANALOG Converter works only with wired headphones.
However, the phone also supports a hi quality APT-X HD Bluetooth codec, so pairing it up with a good set of bluetooth headphones that support APTX-HD will also give you very good sound quality. If you plan on listening to streaming media or regular MP3, and not "lossless" audio files, then I'd go with a good set of bluetooth buds or headset that support the APT X-HD.
David
Another thing to consider....many Bluetooth headphones also are able to work with a wired connection and generally come with a cord that enables you to do so, for example my Bose QC35's. When I use the headphones with the wire / cord, the DAC is engaged. Just make sure you audition the phones in both Bluetooth and wired modes, sometimes the results in wired mode are disappointing / different.
By going this way you have Bluetooth for convenience and wired for more critical listening.
The Bose are great at noise cancelation. Not the best option in that price range if you want high end sound. The noise cancelation also impacts the sound quality. They are great headphones but there are better options in that price range or even way less money for wired sound.
I recommend the Sony H.Ear Wireless. I got them for $200 on Amazon New, with Noice cancelling, good sound, and it works with the DAC. Sadly, they don't trigger High Impedance.
Thinking of getting a nice pair of headphones and considering Bluetooth for mobility reasons. But I'll go wired if this phone can't do what it was designed to do. Anyone have any experience?
How about the apple pods?No. The DAC, or Digital to ANALOG Converter works only with wired headphones.
David
How about a recommendation for pair of wired ear buds (not over the ear) in the $50-$199 range for general listening (music, movies, phone calls) - that gives the V30's DAC a workout - and one that actually outputs some decent VOLUME....?
I get not nearly enough oomph on my last numbers of both plug in and BT buds (and even car interface and a small BT speaker) with either my LG G5 or new V30.... ...walking out to my mailbox I can't hear much of anything if a car goes by, e.g.
