Does my home screen look too busy?
my wallpaper is pitch black with some bubbles so that my apps can stand out. Your wallpaper does look a bit confusing.
This may sound stupid..... But how to you create a folder? In setting I see folder, and ways to customize etc..... But maybe the option isn't there because my home screen is full? Or do you just drag an icon over another?
Yes, drag and drop. Then you can rename it. And you can drag folders in the dock which is why I love Nova.
My home screen.
Here's mine on galaxy tab 3!!
All my toys including my G3, iPad and iMac are clean.
My G3
The Japanese is Starbucks app. Simple Text.
Sent from my LG-D852 using Tapatalk
I think mines too busy if anything, but I find it very easy to find stuff for me. I use nova launcher and a few gestures and more. Love it to make my old Galaxy Nexus seem newer without having to upgrade.
Holy crap. You use to have an Iphone didn't you. Surprized you didn't delete the app drawer after you put all the apps in folders.
Well I cleaned it up a bit, I love all the input here.
Live wall paper as well...really pops.
What you guys think?
Bravo on removing the app labels! Such a simple thing that really cleans up a screen. In my opinion if you need a label to know what the app is, you probably don't really need it on your device to begin with.
Thank you....that was my first day or so with Nova, so ya know....I quickly discovered that I didn't need them and got rid of them and yeah if you don't recognize an app....you don't need it!
Anyways, I think it looks pretty good and clean.....
Yeah, I've messed around with removing the labels. I just think it looks weird on my set up so I've opted to keep the labels. I definitely don't need them to know what the apps are but I just don't really like the way it looks without them on my set up.
Mine is "busy" and I like it that way! I use the homescreen as a dashboard and control center. Status at a glance. The most important apps are in the scrolling dock. The other screens have groups, etc.
Does that HD widget tilt lock switch work, i cant get it to on mine, you tilt it left to right or right to left yea?
Edit: ah i missed the point it locks orientation, i thought it locked the screen when you tilted the phone lol
It may be busy, but I can see its usefulness to the user.
mcheck
