Does redmi note 7 pro is hi-fi audio compliant or not.
rupeshforu3
57
8
Hi I am Rupesh from India and at present I am using redmi note 4 with 64 GB and snapdragon processor ie., mido. I want to buy a new smartphone which provides high quality audio ie., which has separate component for audio processing.
Two years back I thought to buy a new smartphone which has separate component for audio processing and found that mi note series smartphones have separate component for audio processing and I have brought redmi note 4.
At present I am searching for a new smartphone which has separate component for audio processing and so I have examined the specifications of redmi note 7 pro and unfortunately I found that it does not have separate component for audio processing I mean it is not hifi audio compliant.
At present I have also searched for other smartphone which has separate component for audio processing and found a smartphone named zte axon mini ion gold. This particular phone is very affordable.
I would like to buy redmi note 7 pro happily if it is hifi audio compliant. Can anyone of you suggest any other smartphone which is hifi compliant and at the same time affordable.
Please examine the following links and also examine the specifications of redmi note 7 pro and confirm whether it is hifi audio compliant or not.
https://www.mi.com/global/minote/hifi/
https://www.amazon.in/ZTE-AXON-Mini...14?tag=tech0e7-21&ascsubtag=UUacUvbUpU6557638
Regards,
Rupesh.
All phones, all computers, have a "separate component" for audio, called a DAC (digital to audio converter). Files are just ones and zeros, not sounds, so the DAC concerts them to sound. Some phones have better DACs than others, some have better speakers than others, so keep looking around here for complaints, posts about sound, and you'll learn which phone has good sound.
TheGreatApe00
