Does the Honor 8 have heating issues?
I was setting up the new phone and downloading apps and it only got slightly warm. The phone seems to prefer heavy throttling over letting the phone get hot when installing lots of apps
Hi, have you noticed any throttling under other circumstances other than downloading and installing apps?
Cheers
Johnvicentt,
Having a warmer device with heavy use of an application is normal. We advice closing out the app when you're not using it and make sure you're updating your Honor 8. Enjoy! (RL)
Hi guys i have a heat issue when i am playing heavy game like asphalt 8, wwe immortals other than that it does not have any heating issues
When you say issue.. Is it got enough that it is uncomfortable to hold? Does it cause the phone to throttle?
phones will get warm during intensive applications.Now if it gets scalding hot then that's a problem.
It gets really hot for me, but I've learned to live with it - my case tends to absorb most of the heat
How hot is "really hot" - is it so hot that you couldn't hold it (without a case)? If so, please consider exchanging or retiring your device - it may be a danger to you.
I think there are a few apps that will keep track of how hot your phone is running. I know gsm battery gives a graph that's pretty helpful.
Personally I like battery monitor widget, but there are a number of apps that can monitor battery temp.
elowen89
