Does this battery consumption look right?
cjtkd
Active member
Oct 21, 2016
27
So I've been using my phone a lot this past couple of months so I've not paid the slightest bit of attention to battery life. By chance yesterday I thought it seemed to be chomping through battery pretty quick so I fully charged today and took this screen grab just now.
I'm not all that clued up on how android is reporting use now, does this seem 'normal or withing expected range?
Thanks in advance
If you use the Facebook app alot, I would consider disabling it and using Facebook Lite instead if you're okay with the Lite one's more basic look.
Or just use in the browser. FB is definitely a battery hog.
Sadly I use it a lot for work, however I don't remember it being this hungry in the past? I tried reinstalling but still reporting like this. Is this normal?
Trust me to look lol. I should have stayed oblivious
Is your cell signal usually like that, or is it worse in a particular location? Poor cell signal can contribute to battery drain.
Like this when I'm at home, however this isn't a new thing and this change in battery drain is. I'm not sure if it relates to the last OS update?
Could anyone else post a screen shot of how their Facebook app is behaving? Is it normal to have so much background use?
Thanks in advance
For Facebook you can turn off background activity , and put app to sleep in device care
Sure, however I've never had to do that in the past so I wondered why now?
People are sending a shed load more messages recently so your sync will be more active using both antenna and CPU power on the app. Delete all the people talking tosh.
Battery life here is outstanding since i preordered the Note10 Plus on release day still getting awesome Battery life.
dumpsterrentals103
