Doesn't work - hold the volume up, volume down, and power buttons simultaneously
bzeemomof4
I have a fascinate with verizon froyo installed - i was trying to root using the thread First time rooting walk-through 4/28/11. All went well until i had to boot into clockwork recovery by holding Volume up+Volume down+Power button simultaneously. Nothing happens. I received the Pass massage in Odin. The phone is still plugged into computer w/o battery. Please help i don't want to turn on the phone and mess anything up further.
Thanks!!
Unplug the phone from the computer. Insert battery and boot into CWM. That should work. After flashing so many different ROM's using ODIN. I've never rebooted a phone up still plugged into a computer with no batter installed. Try it out and see if that works. Usually if ODIN says it passed, it should be good to go. Hope you didn't hit the "Phone" button in Odin. ;-)
Reactions: bzeemomof4
Re: Doesn't work - hold the volume up, volume down, and power but
My phone is stuck on the green and white htc screen. When I hit all the buttons it restarts but nothing happens. Any idea what is going on?
hi i have micromax a101 , when i press power button+volume up+volume down it just keep on vibrating until i remove the battery.is there any solution for this.
kiki2025
