benny3
Flashoholic!!
- Sep 2, 2011
- 2,222
- 40
- 0
Re: Downgrade from 2.17.651.5 to 2.08.651.2 with locked hboot 1.5
sure you can get what you say fully rooted on 1.5 its the rom thats rooted and not the phone. so if you flash a rom thats rooted then you have root ,if flash a rom thats not rooted then your not rooted. the HTC unlocked method is more than temporary, it last as long as you want it
Success! I found that not all versions of 2.17.651.5 are created equal.
By writing this RUU .exe update over the existing ROM (same 2.17.651.5 version number) I could unlock the bootloader with no problem. Not really
This was posted by bobodobo. Yes it works, but it only unlocks the bootloader temporarily with the htcdev method. NOTE: you don't gain S-OFF but you can flash kernels/ROMs
As of yet no one has been able to fully root the HTC evo 3d on software number 2.17.651.5 with hboot 1.50 running 2.3.4
