Droid Body Glove review by a Verizon Agent
eljoker
85
Ok so I went out and bought the body glove because Im always showing off my phone and im used to cliping it to my side plus having it makes for a perfect way to get an accessory sale out every time I sell a droid.
Well I in terms or protection 5/5
But 3 things that really dont work for me.
1. Everyone complains about being able to hear me. The mic gets muffled even with the cut out on the faceplate.
2. You have to be real carfull when putting on the bottom peice because if your not the tabs get caught on the seems and literly pop the phone in two. It happen to me yesterday and Im glad I was able to snap the phone back together with out any problems but it scared the **** out of me.
3. I have to clip it with the the the screen vertical and then rotate it so the soft keys are pointing FWD if i clip it on the right or towards the back if on the left because the keyboard slides out easily.
Perfect for protection but not what I need. Im still going to keep it but I think im just going to slap it on my demo and leave it there.
This case is great for protection but it is HUGE make the phone way to bulky, so if you like to carry your phone in your pocket I do not really recommend it.
I've personally found the phone to be of such solid build I don't even need a protective cover
The glass is almost unscratchable, and the rest is pretty tough plastic or metal.
The battery cover might be scratch prone, but it's 10 bucks to replace
Another reason i got the case was because the door cover was getting lose.
Im just going to get the invisisheld.
I think this will be a common problem for Droid owners.
levertisbree
