Droid Maxx 4.4 Fix coming within "Days"
Yeah, me, too. Reading all the posts, and I've not found anything diff yet. At all.
The only thing I notice is the transparent status bar, which I'm personally not a fan of. :(
Huh? The only place there is a transparent status bar is on the lock screen. The bar on mine still has the black background unless I'm missing something?
I am now using GW and ISIS downloaded from PlayStore. I could not do that on 4.2.2! For me that is a BIG BIG difference.
Gw?
I use Isis on 4.2.2 just fine. I use root cloak to hide root. Even got $50 for free setting up Amex serve...
Sent from my XT1080m using Tapatalk
Got the update OTA and it has broken bluetooth for me. Previously the phone worked great with Sync my car. Now it doesn't connect. I tried unpairing and repairing the device and it worked for a minute then the bluetooth disconnected. Way not happy...
Try doing a factory reset. It might be cache from Jelly Bean.
After my 4.4 OTA update, my phone is shutting down randomly every 10-20 minutes. I have to assume my phone is turned off if it has been in my pocket for any length of time. It also means, I need to dig out an alarm clock, because, like this morning, I know it won't be waking me up for work at 5:45 tomorrow morning. On a plus side, my battery life is great!
I did a factory reset, but it did not resolve the issue.
If a factory reset didn't solve it, it sounds like it's time for a warranty replacement.
Mine mysteriously shut down three times last week. Had the update since the soak and never happened till then. Seems to be doing OK so far post reset.
if you can read this, you're standing too close
Prior to KitKat, my phone randomly reset itself twice, both after running for about 21 days without a restart. (It did not power down but restart.) So far since doing an FDR after the KitKat update the phone has been running 28 days 12 hours and counting.
BNI DIRECT12
