I have a 2006 Acura TL that allows a phone to connect via bluetooth for calls only (not streaming for other audio). I assume it is a common interface for Honda around that year.
My MAXX pairs fine, but when I make calls it does not use the connection. It says it is using it. The phone call screen has a selection button at the bottom that allows you to switch between the handset, speaker phone, or bluetooth. It shows bluetooth, but the audio is going through the handset.
If I switch the call to handset or speaker, and then back to bluetooth, then the car will pickup via the bluetooth connection. But when I first make a call it does not connect.
Any ideas?
Any ideas?
