DROID TURBO: Motorola Flip Case
I just got a droid turbo two weeks ago and decided to go with this case because I wanted to check out the notification window software and see if I liked it. I received the case yesterday and from everything I have not gotten any of the software features to work. I have made sure the flip case app is installed and running and any basic troubleshooting techniques from all the forum discussions I have been able to find from a google search. My moto display is on and I am not using the ambient display. I was going to try to reinstall the app, but was not able to find a proper .apk since this app is not one I can uninstall. I also tried a chat case with motorola that went no where fast, so I gave up on that. Could this be a lollipop issue since I did update this week has anyone else had issues with this case since updating or is anyone still using this case?
My Droid Turbo works fine with it. I bought it around 6 months ago with a brown Motorola Flip case. It worked fine on Kit Kat and it also works fine with the Lollipop upgrade...
Only thing I don't like much is that I normally wave my hand at nigh to see the time. with the flip case closed it's almost impossible for it to work, even though the case has two small holes for the sensors to see through.. it didn't work on KK and now with Lollipop still doesn't work.
If you are having problems, i suggest a Factory reset, and if it still doesn't work then I would contact your phone seller to replace the phone as defective...
drayb
