Droid X random reboots while unplugged, in sleep mode
My phone used to have frequent and random reboots when I first got it. Now it doesn’t.
I think most of the time it was because the phone got too hot (over 110 degrees) I figured this was because I was holding it too often at the battery, and because I was using a thick silicone case. I took the phone out of the case and it stopped rebooting.
My first battery was also bad by the way… it only lasted about 4 hours total active and standby time. I got the Moto extended battery (BH6X) and now it lasts for a couple of days with my use.
Oh, but you do have apps installed ... the X comes with several basic ones. Check the My Apps (in menu) when in Market. Make sure they aren't auto-updating. It really doesn't sound like this is your problem, but it's worth a look.
I appreciate the help, but there is nothing listed in the My Apps when in the Market. I know there are plenty of preinstalled apps, but they aren't listed there, and I couldn't figure out how to adjust their updating schedule.
Same Problem
I'm having the exact same problem with no fix still. My first phone fried, the first refurb reset every 5 minutes, and I'm on my second refurb now with the same problem, no fix. I can only talk on speaker, if it's unplugged and the screen goes off the phone reboots. Right now I have my screen set to never go off. And it's highly annoying. Verizon hasn't done much to fix this problem. How can I get a new phone? They only give me refurbs that don't work. I want another droid or iPhone if the X is going to consistently do this crap. I bought it new when it first came out with no problems. I got Gingerbread on it and it died. Now I've got 2 rebooting bricks in my house.
davidlmcshane
